Trailer Wiring Harness - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 10-05-2011, 07:51 PM   #1
Grampa Dicky
ROC Rank: Freshman
2008 RTS
Billet Silver Metallic
Installed a Curt hitch on my 2008 Ridgeline, went great! Then installed the wiring harness #55585 and the parking lights are not working. All the other lights work fine.
Does anyone have any suggestions or have used this harness? --- Thanks, Rich
Grampa Dicky is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-06-2011, 12:37 AM   #2
Elkhunter
ROC Rank: 1k Comma Club
2007 RTS
Aberdeen Green Metallic
Elkhunter's Avatar
Re: Trailer Wiring Harness
Start by checking fuse #4 for the "small lights" in fuse box near drivers left foot. It will probably be fine but it's a place to start.
The harness is pretty simple, yellow on the drivers side, green on passenger side. Black box in the center. If all connectors are plugged in solidly, it would seem odd that all the parking light bulbs would burn out at the same time, so maybe a bad "black box"?
Question...is there any sign that there had been a hitch installed previously? Perhaps through splicing into the wires rather than the t-connectors you are using? If so, maybe a bad connection in the taillight area?
Full Size Spare, USA-Spec iPod adaptor, Westin powdercoated sidesteps, OEM tow hitch & harness, 2009 camera handle, Back-up camera, 3.6-inch Boyo Monitor (with second camera on rear of teardrop trailer), Trunk carpet, Trunk dividers, Billet Grill, Infinity Reference 1031t Tweeters, Full-time power to front and rear 12V outlets, Fumoto oil drain valve, FIGS G2 hood prop kit. Rhino 360B Hitch step, Rear Splashguards, 255/65/17 MS2's
Elkhunter is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 06:51 AM   #3
Grampa Dicky
ROC Rank: Freshman
2008 RTS
Thanks for the quick reply. Will try what you said and will keep you posted.
Thanks,
Rich
Old 10-06-2011, 11:04 AM   #4
Grampa Dicky
ROC Rank: Freshman
2008 RTS
Tried the #4 fuse it looked fine so I disconnected the new T-harness and reconnected the rear lights and the parking lights still don't work. The front two do work but not the rear two. The bulbs look fine. Frustrating. I don't understand the fuse chart as to which fuse it could be. Wouldn't the rear parking lights be on the same fuse as the fronts??
Any help is appreciated!
Old 10-06-2011, 12:39 PM   #5
speedlever
Moderator
2008 RTS
speedlever's Avatar
Fuse locations and assignments:
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 10-07-2011, 07:19 AM   #6
Grampa Dicky
ROC Rank: Freshman
2008 RTS
Thanks for the diagrams, big help but still no rear parking lights. Checked all the fuses and bulbs, something isn't right. Might have to bite the bullet and bring it to the dealer.
They said it's covered if its a wiring problem.
Old 10-07-2011, 08:57 AM   #7
tech35
ROC Rank: Sophomore
2008 RTL
Nimbus Gray Metallic
tech35's Avatar
Yet another fine post by Speed to keep in your bookmarks or print the page people... thanks Speed
The quality of a man's life is in direct proportion to his commitment to excellence, regardless of his chosen field of endeavor...Vince Lombardi
tech35 is offline   Reply With Quote Quick reply to this message
Old 10-07-2011, 01:44 PM   #8
Elkhunter
2007 RTS
Elkhunter's Avatar
Ooops...had the right fuse, but gave the wrong fuse box location...sorry
Old 10-11-2011, 10:09 AM   #9
Grampa Dicky
ROC Rank: Freshman
2008 RTS
For all you Do-it yourselfers like me, the rear tail-lites are on the #4 fuse under the hood in the primary box labeled "small lights". Thanks for all the info!!
And for everyones knowledge, The rear yellow tail-lites are for directionals only. As it turned out, everything was cool!! No problems except my stupidity!!
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Trailer wiring harness instructions Spydr26 Exterior 6 06-10-2009 09:53 AM
Where to grond E-trailer wiring harness? SkepticDoc Racks, Hitches & Towing 3 03-19-2008 06:30 AM
5 Pin Wiring Harness for Trailer? RobDerhak Racks, Hitches & Towing 2 02-13-2008 09:16 AM
Trailer Wiring Harness blubelt Racks, Hitches & Towing 0 09-09-2007 10:46 AM
2007 trailer wiring harness? pep Accessories 4 06-06-2007 01:58 PM
