VTM-4 and Check Engine light (NOT GAS CAP) - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 10-09-2011, 12:38 AM   #1
Danick
ROC Rank: Freshman
2007 RTL
White / Olive
Driving home last night stopped at a light, suddenly my RPM drops to 400 then back up to 1000 and back and forth like its gonna stall. Check engine light comes on too. Drive a few blocks and the VTM comes on as well and now the trauck is lurching and ridding ruff. Park it check fluids gas cap etc... all god. Start it up and it sounds like an old beater almost backfiring and still iddling rough. Make the decision, right or wrong, to limp it home truck runs secent but everyonce and a while on the way it starts to shake and shimmmer, then smooth out. Any one have any idea what this might be?
Of course its the long weekend so can't get it looked at till tuesday, till then it will sit in my garage.
2007 Honda Ridgeline 97,000km
Danick is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-09-2011, 12:47 AM   #2
MikeT
Mall Ninja Moderator
2006 RTL
Billet Silver / Gray
MikeT's Avatar
Re: VTM-4 and Check Engine light (NOT GAS CAP)
Using the Google Custom Search tool just below the top blue banner with key words "VTM-4, CEL, Check Engine Light", I got several hits including the one below:
http://www.ridgelineownersclub.com/f...p/t-39325.html
2006 Ridgeline RTL, Silver with roofrack.
2000 Accord V6 EX, White no roofrack.
MikeT is offline   Reply With Quote
Old 10-09-2011, 06:08 AM   #3
Ourfarm09
ROC Rank: 3k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Get the codes checked first and test the battery
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote
Old 10-13-2011, 04:59 AM   #4
winggirl2004
ROC Rank: Freshman
Exclamation Re: VTM-4 and Check Engine light (NOT GAS CAP)
That just happened to me a few months back and I'll tell you this make sure where ever you bring it you trust!! I went to 2 dealerships with totally different answers after being fustrated I went to a independent shop and they overlooked a few things also, the result?? my truck the day before bringing it to be checked and possibly fixed it started on fire. The spark plug blew out hit the radiator which caused a spark
have someone check the spark plugs!!! the codes dont mean a thing!!! I got those checked and it was something totally different
winggirl2004 is offline   Reply With Quote
Old 10-13-2011, 05:45 AM   #5
Rickman
ROC Rank: 2k Comma Club
2007 *Former Ridgeline Owner
Nimbus Gray Metallic
Rickman's Avatar
That is the oddest story I have ever heard! Hope everything went ok, after that!
Danick, I would also have the battery checked if that is the original one!
Stranger things have happened to RL owners, and that was usually the culprit! Mine just died on me without warning, but others have had different results..
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!
My other ride is my Bicycle!
Rickman is offline   Reply With Quote
Old 10-13-2011, 05:46 AM   #6
chiph
2006 *Former Ridgeline Owner
Steel Blue Metallic
Bad gas? Did you just fill up?
Chip H.
Former owner: 2006 Ridgeline RTL
chiph is offline   Reply With Quote
Old 10-13-2011, 07:50 AM   #7
GTwannabe
ROC Rank: Junior
2011 *Not a Ridgeline Owner
Bali Blue Pearl
Sounds electrical (battery or alternator)
GTwannabe is offline   Reply With Quote
Old 10-13-2011, 08:03 PM   #8
TRacer
ROC Rank: Junior
2007 RTS
Billet Silver Metallic
TRacer's Avatar
I had similar symptoms and the same warning lights after my truck sat for a month and I tried to drive it when I returned from vacation. I pulled the 15 amp ECU fuse (#8 in the fuse box by the passenger side fender), put the battery on a good 2 amp trickle charger overnight, reinstalled the fuse the next morning, did the idle learn procedure and now all is good. My battery is not the original.
'07 RL RTS (custom switch to completely shut off VSA which also disables ABS (good for use on sand and mud with low tire pressures), Sprint Booster)
H-D "old skool" XLC (suicide clutch/jockey shift, 21" spool, D-I-Y air cleaner, left hand throttle, direct push button on starter)
<-- 1939 Homebuilt teardrop with axle from a 1917 Hupmobile Model N
TRacer is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
CEL came on for gas cap...then VSA light...then VTM light... TRacer Problems & Issues 5 08-24-2011 03:06 PM
VTM and Check Engine lights ON joe vt Under The Hood / Performance 18 05-22-2010 10:15 PM
Check Engine/VTM-4 light on... CrowMagnumMan Problems & Issues 9 12-19-2009 07:38 PM
check engine and VTM-4 light on miroslavp Problems & Issues 3 02-28-2009 07:32 AM
HELP, no VSA, no VTM, Check Engine light on. Luder62678R1 Miscellaneous/General Honda Ridgeline Discussions 10 04-16-2006 07:30 PM
