Diesel Ridgeline? A glimmer of hope... - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Miscellaneous/General Honda Ridgeline Discussions
Notices
Thread Tools Display Modes
Old 10-26-2011, 07:38 AM   #1
csimo
2014 SE
White/Black
csimo's Avatar
History: Honda was developing a V6 diesel engine that would have powered the Ridgeline, Pilot and Odyssey. The engine design was a good one, but it required urea injection to meet US EPA regulations (which are biased against diesels). A change in management scrapped the program. Honda also has a very good I4 diesel that they use in many other areas of the world other than North America. That engine was slated to go into the Acura TL but the new management scrapped it only a few months from introduction.
Fast forward a few years to today. I heard a little whisper that Honda is revisiting the North American diesel engine program(s). There is industry wide anticipation of EPA changes that would remove some of the unfair diesel regulations for passenger car diesels.
Does this mean we'll see a future diesel powered Ridgeline? I don't know. I suspect that if there is something going on at Honda regarding diesel engines they will put all the emphasis on the I4 engine.
I don't think there's any 'official' money being spent on the diesel program right now, but it seems there's something stirring.
We won't know anything for a couple of years, and more like 3 years before any product hits the market... but keep this thread in mind.
-Joe
csimo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-26-2011, 08:08 AM   #2
arteegee
ROC Rank: 5k Comma Club
2006 RTL
Steel Blue / Gray
arteegee's Avatar
Re: Diesel Ridgeline? A glimmer of hope...
Great news Joe!
#567 HPD-Shut Up and Drive...
arteegee is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 09:07 AM   #3
GTwannabe
ROC Rank: Junior
2011 *Not a Ridgeline Owner
Bali Blue Pearl
A few problems:
1. Diesel is more expensive than gas outside of interstate truck stops
2. Not every gas station carries diesel
3. Diesel parts are expensive; Honda's not saving any money over something like an Ecoboost 4cyl since you still need a turbo and forged parts
4. Obnoxious repair costs (a broken injector is much more likely to cause catastrophic engine failure)
5. Additional maintenance and hidden costs (frequent fuel filter changes, more engine oil per change, dual heavy-duty batteries, etc.)
6. 75% of owners are idiots who do not read the owner's manual. They will get their oil changed at Jiffy Lube-type shops that will use regular motor oil instead of the correct diesel rated oil. Hello sludging.
7. Diesel MPG's have been dropping due to the whims of the EPA. Some manufacturers have gotten around the use of urea by dumping excess fuel through the motor during regen cycles. I would rather add a bottle of urea every oil change.
GTwannabe is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 09:41 AM   #4
csimo
2014 SE
White/Black
csimo's Avatar
Originally Posted by GTwannabe View Post
A few problems:
6. 75% of owners are idiots who do not read the owner's manual. They will get their oil changed at Jiffy Lube-type shops who will use regular motor oil instead of the correct diesel rated oil. Hello sludging.
I'm not trying to criticize you individually, and your perceptions are of the average person.
#1: According to the US Energy Information Administration the average cost of a gallon of gasoline on October 24, 2011 is $3.462 per gallon. The same info for diesel is $3.825. When we compare real numbers of fuel efficiency of diesel vs. gasoline we generally end up with diesel being about 27% more efficient than gasoline. Diesel fuel contains more energy per gallon than gasoline and lends itself to more efficient delivery and burn processes. So using that number we find that if we paid $3.825 for a gallon of diesel fuel we should only pay $2.792 per gallon for gasoline. So the price of gasoline is the one that's out of line, not diesel.
#2: I agree that not every station carries diesel fuel. This varies considerably by location. In my part of the country it's unusual to find a station that doesn't have diesel fuel. As more and more diesel powered passenger vehicles come to market you'll find this problem (if it really is a problem) will vanish. Keep in mind that you will need to visit the fuel station fewer times in a diesel powered vehicle as well.
#3: If we use VW, BMW, and Mercedes Benz as real world examples I think you'll find that the repair costs are lower, and reliability and resale value are higher on their diesel powered vehicles vs. the essentially similar gasoline powered vehicles.
#4: Since there's a rapid movement to GDI (Gasoline Direct Injection) I think you'll find the costs and potential engine damage are the same as diesel. GDI is essentially a diesel injection system on a gasoline engine. Moot point.
#5: Again using VW, BMW, and Mercedes-Benz as examples I think you'll find the maintenance cost is very similar to the gasoline counterparts. Most have 10,000 mile service intervals which is longer than the average gasoline engine. Fuel filters are essential, but that's really a problem with our low quality diesel fuel in the USA. Things are getting better. As for batteries... I think you're comparing apples and oranges. Passenger car diesels don't use dual battery systems.
#6: I think this applies equally to all owners. As for sludge... talk to Toyota owners about that.
#7: As I pointed out in the original post... manufacturers have good reason to believe some of the unfair EPA diesel rules will soon be changed. I think we'll see urea, diesel particulate filters, and other nonsense removed from passenger car diesel regulations within the next 2 years.
I challenge anyone to drive a modern diesel powered vehicle and tell me they don't drive better in nearly every respect than the same car with a gasoline engine. Nearly every review of the VW Jetta and Passat point out that the TDI is the version to get. Same with the Mercedes-Benz offerings.
Better fuel economy, better reliability, fewer fuel fill-ups, and higher resale value. That's reality. From the numbers I heard in 2009 the Ridgeline would have been rated at 27MPG highway and 20MPG city with the V6 diesel. The premium was $4000 which would have dropped if production increased. You could reasonably say a diesel would be worth at least $2000 more on the back end resale if not more. It's a no brainer... diesel is a good thing.
-Joe
Old 10-26-2011, 10:19 AM   #5
SouthernRL
ROC Rank: Freshman
2012 RTL
Polished Metal Metallic
I can prove a case for diesels in one word....Torque. And lots of it at low RPM's, perfect for the kind of driving we do in the US. And great for towing.
I recently had the opportunity to drive a 2011 BMW 335d. It was the most fun I've ever had behind the wheel in a car. No smoke, no clatter, no smell, just fast as stink and 36 mpg.
If you haven't driven a diesel lately, it's not your fathers diesel.
I'd buy a diesel RL in a millisecond.
SouthernRL is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 10:23 AM   #6
bdk584
ROC Rank: Freshman
2011 RTL
Sterling Gray Metallic
bdk584's Avatar
Hay csimo,
Great job. your facts are right on point.
Bill
bdk584 is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 10:40 AM   #7
Ian Brantford
ROC Rank: 2k Comma Club
2009 VP
Excellent thread.
Can anyone comment on how diesel compares to gasoline for short trips? I.e. is one notably better or worse if you just drive a cold engine for a few miles?
Ian Brantford is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 11:13 AM   #8
AG87BlkLX
ROC Rank: 1k Comma Club
2006 RT
Nighthawk Black / Beige
AG87BlkLX's Avatar
Too bad this is like 3 years out.
AG87BlkLX is online now   Reply With Quote Quick reply to this message
Old 10-26-2011, 11:14 AM   #9
GTwannabe
ROC Rank: Junior
Bali Blue Pearl
I would have no problem buying a diesel RL... I just don't see Honda dipping their toe in the segment when they have yet to modernize their gasoline engines and transmissions beyond mid-1990's technology.
If Honda does release one, it will have a cult following like the Liberty CRD and Volkswagen TDI's. Both of which have had their share of problems (Liberty motor had to be detuned to prevent tranny damage, TDI had problems with cam lobes wiping due to low zinc oil)
Old 10-26-2011, 11:55 AM   #10
xd9x19
2006 RTL
White / Beige
xd9x19's Avatar
Thanks for the info, csimo.....those 20/27 mpg figures sure sound sweet.
xd9x19 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
What would you pay for a Ridgeline Diesel? MoosePond Dear Honda: (Feedback Forum) 264 12-22-2011 09:36 AM
the ulimate best sounding ridgeline system... I hope Chefelvis Mobile Electronics 48 01-14-2010 07:53 AM
I hope Honda brings a diesel soon. Read this.... (30-35 MPG!!!) Rodek Other Cars, Trucks and Bikes 38 02-15-2008 05:52 PM
2009 Ridgeline will have a diesel qlake Shoppin' and Test Drivin' 12 12-25-2007 09:02 AM
Ridgeline, Others Could Get V-6 Diesel [12.4.6] swampler Headlines 9 12-11-2006 03:24 PM
