Stuck in Park - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 11-08-2011, 05:53 PM   #1
ejarmbrister
ROC Rank: Freshman
Stuck in Park
I just had all new disc brakes put on my 2006 Ridgeline.......now it sticks in park? Do I need to adjust the the brake? How?
Also, triangle warning and ABS warning come on?
ejarmbrister is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-08-2011, 09:14 PM   #2
Oddjob
ROC Rank: 1k Comma Club
2009 RTL
Bali Blue Pearl
Oddjob's Avatar
Re: Stuck in Park
Maybe the brake guy adjusted the rear brakes to tight. And when you put your foot on the brake pedal to release the transmission lock it won't activate it. Can you get it out of Park with the Emergency release pressed?
Is the Parking brake on?
2006 & 09 RTL w/o Nav. Motto: "Be not drunk with wine." EPH5:18 As I spent 10years in a BATU.
RETIRED March 2011
Oddjob is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 04:16 AM   #3
ejarmbrister
ROC Rank: Freshman
Re: Stuck in Park
Thanks, I'll check into that! Also, problem did not start until next day??
Old 11-09-2011, 01:26 PM   #4
DeuceRon
2011 RTL
Dark Cherry Pearl
DeuceRon's Avatar
Re: Stuck in Park
If your brake pedal moves and the lever won't disengage, my guess is that something in the transmission release system became disconnected from the brakes. I don't know if it's just an electronic sensor or if it's mechanical, but to me that's what it sounds like if your brakes were replaced.
I'll betcha OurFarm will know for sure..
Ron..
[FONT="Comic Sans MS"]2011 Ridgeline RTL Nav - Dark Cherry - OEM hood shield, OEM roof rack, Husky floor mats, S5 Dude's custom sills and plate frame, bed graphics, Truxedo cover, vent visors, Raptor stainless tubes, Dee Zee mat, Infinity Reference dash tweets, Sportwings, OEM rear seat mat, 20" TSW Vortex Wheels and Nitto NT 404 Tires, Rampage LED tailgate bar, Stainless bull bar
2007 Lexus RX350
2008 Roush 427R Mustang
2014 Mustang
DeuceRon is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 01:59 PM   #5
ejarmbrister
ROC Rank: Freshman
Re: Stuck in Park
Thanks for your thoughts.........what is Ourfarm??
Old 11-09-2011, 02:43 PM   #6
OldNorske
ROC Rank: Senior
2006 RTL
White / Beige
OldNorske's Avatar
Re: Stuck in Park
I can't see how this would be related to a brake job...however, if pushing on the brake pedal (as we have to do to trip the brake switch) to get the transmission out of park doesn't work, I have to think the brake switch is disconnected or not functioning.
This switch turns on your brake lights when you depress the pedal. It also deactivates the cruise control, if cruise is in use.
If this switch is not working you will not be able to get the transmission out of park.
There is a a little square piece of plastic that can be removed with a small screwdriver. Under this plastic is a switch that you can depress to get the transmission out of park and drive normally (except for the fact that you won't have brake lights or be able to use cruise control).
If I remember right, the plastic tab is located on the steering column, but I may be wrong. Some one will correct me....
The switch is located right above the brake pedal. It is activated by the metal linkage that the pedal is mounted on. You may have to be a bit of a contortionist to get to it.
OldNorske is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 04:10 PM   #7
Ourfarm09
ROC Rank: 4k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Re: Stuck in Park
Ourfarm would be me....
There are a few things that could be causing this and most have already been mentioned by oldnorske. Now it is puzzling that the ABS light and triangle is on. But that shouldn't cause the shift lever to stick in park.
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 04:42 AM   #8
ejarmbrister
ROC Rank: Freshman
Re: Stuck in Park
Thanks for your ideas. I have been using release on column to operate truck. Checked cruise and it works fine. will check brake lights today. Also, VSA light comes on!!
I found switchthat touches brake but it appears OK!
What now??
Old 11-10-2011, 05:12 AM   #9
flying butcher
ROC Rank: Sophomore
Re: Stuck in Park
If your brake light fuse is blown it will cause transmission to not come out of park. Been there done that with our Accord.
flying butcher is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 05:33 AM   #10
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Re: Stuck in Park
Fuse locations:
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
I Got Stuck... LUV2REV Miscellaneous/General Honda Ridgeline Discussions 5 01-14-2010 01:24 PM
HELP! BU cam install gone bad: stuck in park w/ windows down! Chris S Problems & Issues 2 08-08-2009 08:46 PM
Need help cd stuck in player angelmojo58 Mobile Electronics 0 02-15-2009 11:47 AM
Stuck! 2007ATLRTL Off-Roading 25 11-27-2007 04:04 AM
