Front map light switch..available by itself? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Interior
Notices
Thread Tools Display Modes
Old 03-05-2012, 08:25 AM   #1
JuiceGoose
ROC Rank: Junior
2007 RTL
Nimbus Gray Metallic
JuiceGoose's Avatar
I've come down with the same issue as some other owners. One map light will work when pressed by not when door opens. Upon inspection the terminal on one of the little switches was severely corroded. I haven't been able to get it clean enough to work right and no matter of fiddling with the lugs has helped so now i will by a new switch. Has anyone been able to source out just the switch or do you have to buy the whole housing like the parts diagram shows?
You pooped in the refrigerator... and you ate the whole wheel of cheese. Wow! really im not even angry thats amazing!!!
JuiceGoose is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-05-2012, 09:35 AM   #2
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Re: Front map light switch..available by itself?
I'm thinking a junk yard might be your best bet. Although it might be worth sourcing the part at your local dealer. Won't hurt to compare price. Thus far, my local dealer has been able to come up with some obscure parts on the odd occasion that I need it.
Come to think of it, that might be a good way for me to put a homelink overhead console in my RTS. Hmmmm.
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 07-07-2012, 08:22 AM   #3
raablong
ROC Rank: Freshman
2006 RTL
Redrock Pearl / Beige
I have the same problem and just came from the dealer. They do not have just the switch available. Looking at the parts diagram, it appears you need to replace the whole base at about $50. However, I can't see the switches on the diagram of the base! You might have to replace the whole module at $400! Either way, once you order the part, it's yours. There is no returning electrical parts.
I think I'm going to be heading to the junkyard...
raablong is offline   Reply With Quote Quick reply to this message
Old 07-08-2012, 04:53 AM   #4
Lou100
ROC Rank: Freshman
2007 RTL
Formal Black
Smile Re: Front map light switch..available by itself?
Try the following web site:
http://www.mouser.com/ProductDetail/...252bMrWoCJLw==
Lou100 is offline   Reply With Quote Quick reply to this message
Old 07-08-2012, 05:29 AM   #5
speedlever
Moderator
2008 RTS
speedlever's Avatar
Lou100, good find.
Since I made my post above, I've discovered my local junkyards (at least the one I checked) has a $50 minimum charge. For $1.84 and shipping, that switch is definitely worth the price!
Old 01-04-2015, 12:18 PM   #6
kdsimms
ROC Rank: Freshman
2006 RTL
Steel Blue / Gray
Originally Posted by Lou100 View Post
Thanks for providing the link for the switch. I see the switch simply pops out. It's talked about here.
http://www.ridgelineownersclub.com/f...ad.php?t=41928
kdsimms is offline   Reply With Quote Quick reply to this message
Old 01-04-2015, 12:25 PM   #7
speedlever
Moderator
2008 RTS
speedlever's Avatar
Yep. It just slides out. You may have to start it with a small screwdriver.
http://www.ridgelineownersclub.com/f...&postcount=109
Old 01-04-2015, 12:46 PM   #8
kdsimms
ROC Rank: Freshman
2006 RTL
Steel Blue / Gray
Thanks, I just figured it out.
Have a great day.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Map light stinger Interior 17 01-05-2015 09:34 PM
Map light on and off patrickcoor Problems & Issues 53 12-08-2012 06:25 PM
front dome light and floor light switch..... marc1957 Problems & Issues 6 09-15-2011 07:03 AM
Map light bulb out. dizzyjoe Interior 3 05-01-2010 01:50 PM
Interior map light in front seat area... wjr1004 Interior 1 07-13-2007 10:15 PM
