Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 03-23-2005, 03:49 PM   #1
Ultra-HOG
Senior Member
2006 RTL
Nighthawk Black / Beige
Ultra-HOG's Avatar
Cool Better Tonneau Cover Wanted! FOUND??
I am searching for a better Tonneau cover than the OEM Honda Tonneau. The Honda unit requires major surgery to the bed to install, is not removeable, and causes the loss of use of the bed for anything that will not fit under it. The front half of the bed becomes a cavern that will be very difficult to access. Come on Honda, look at the quality aftermarket products and engineer one that is usefull. I understand that the Ridgeline is a very new model and the bed is very different than a standard pickup truck bed. A clamp-on side rail may not be possible. The rails will need to go inside the bed and be screwed in place. The bed trunk lid may have a clearance problem for the side rails. Water seals and drains will need to be different than on a "standard" bed design. All that aside, I still think that it is possible to design a better product than Honda has. The OEM Honda installation manual is freightning. If you are happy with the limitations of the OEM unit, I am sure that it is solid and durable. There simply must be a better design. If anyone knows of a retractable unit I certainly would like to know about it. I searched Google for Tonneau and looked many sites without success.
Ultra-HOG is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-23-2005, 03:59 PM   #2
Ridge
ROC Rank: Ham
2006 RTL
Steel Blue / Gray
Re: Better Tonneau Cover Wanted!
It may take some time for the aftermarket companies to catch, but thanks for the info on the Honda cover. I may just leave mine open.
www.karynwhittemore.com
Ridge is offline   Reply With Quote
Old 03-23-2005, 05:26 PM   #3
Ultra-HOG
Senior Member
2006 RTL
Ultra-HOG's Avatar
Thumbs up Re: Better Tonneau Cover Wanted - FOUND??
Hold on! I just heard back from the owner of BAK Industries (www.bakliner.com). He checked out a Ridgeline and he has a plan for a revised design of an existing product that they manufacture. It is a retractable / roll-up unit that they have been successfully selling for other trucks. Just what I am looking for! He expects to have one available in a little as two weeks! I was very impressed with everything that I see on their web site and with the interest and follow-up on my inquiry. He mentioned that it will be mounted to the inside walls of the bed and will follow the lines of the top rails. That will make it slope toward the rear which will allow water to run off the back and out of the tailgate. The rails themselves will allow water that gets over the edges to run out the rear as well. For those of us that live North of the Mason-Dixon line, freeze-up may occasionally be an issue. No different than on other similar products but with the slope of his proposed design it may be less of an issue on the Ridgeline than on other trucks. I think that I would still prefer a horizontal installation for appearance reasons but it may not be possible if you want to keep the water out. I will wait somewhat patiently to see the final design. Please don't take any of this as fact yet. This is all just based on a telephone conversation about a prototype that has not been built yet. I am very anxious to see the final product. I just may be the first customer! I will post anything else that I find out.
Old 03-23-2005, 05:46 PM   #4
zero
Challenged Moderator
2006 *Not a Ridgeline owner
zero's Avatar
Send a message via AIM to zero
I just finished watching the installation video. Looks fairly simple to install. Definitely keep us posted. I really like the retractable design.
When we have no thought of achievement, no thought of self, we are true beginners. Then we can really learn something.
zero is offline   Reply With Quote
Old 03-23-2005, 06:42 PM   #5
delphi7x10
ROC Rank: Turkey
Ultra-Hog,
While I like the roll up cover design, I had a chance to see one a couple of weeks ago, I question how it could much easier to install or remove on the Ridgeline. You state he is planning to have it follow the lines of the top rails so it slopes to the gate. Well that sounds great, but if you look at the pictures of the Honda cover you will see it comes to the bottom of the rear window, this design sounds like it will have to go above the window. Also won't the bed liners still need to be removed and cut to install it
On the FAQ page it mentions this must be done for some trucks with bed liners, so no ease there.
I like the idea, and I do hope he can pull it off, if he posts some picture of progress, perhaps I would hold off and wait, but at least I know with the Honda cover I can get it now.
Also I see if does not have an Avalanche cover, which has many of teh same problem as ridgeline for install, and its been out for a while.
delphi7x10 is offline   Reply With Quote
Old 03-24-2005, 04:23 PM   #6
Matthew Dworman
ROC Rank: Stuffing
2006 RTL
Billet Silver / Gray
Thanks for letting us know about that! The OEM one looks cool, but definitley lacks in user-friendliness. When I asked my dealer how much it was, he called the parts department and I heard this: "Oh really, well you can tell Honda that we will NEVER order one of those!" At a dealer cost of nearly $1,200 PRE-install, you can be sure that it will not be one of their best selling items. Please keep us posted as to when you see a release of the aftermarket tonneau covers!
Thanks,
Matt
Matthew Dworman is offline   Reply With Quote
Old 05-13-2005, 03:46 PM   #7
hondaguy
ROC Rank: Stuffing
I have heard that Access Covers are going to be offered for the Ridgeline. Check them out they are a roll-up cover. http://www.accesscover.com/
hondaguy is offline   Reply With Quote
Old 05-24-2005, 02:02 PM   #8
coolcat
ROC Rank: Mashed Potatoes
2006 RTL
coolcat's Avatar
I've been talking to Cheri at Agri-Cover today about the Access Cover for the Ridgeline. She says that it will be available next week and that the MSRP is $489. I posted a picture in another thread here, so I won't post it again but it you want to see it it shouldn't be too hard to find.
coolcat is offline   Reply With Quote
Old 04-25-2006, 10:44 AM   #9
Torza Tonneau Guy
ROC Rank: Stuffing
I am a dealer for Advantage Torza Tonneau Covers.
Advantage has made many improvements to their Honda Ridgeline Torza Tonneau. I would like to provide you with some updated information.
I read where some owners had issues installing their rail because of holes not lining up, this has been addressed. The rail has a new improved end cap with re-positioned holes in rail for easy installation of rail. The rail is now mat black finished to match inside of Ridgeline bed. The rails have also been relieved more to allow trunk door to open further. Rail is padded in this area to keep door from getting scratched when opened.
Advantage has added safety teathers, and a new clip type fastner on bulkhead, used when cover is in open position.
There are "4" different Torza Tonneau's to fit Honda Ridgeline.
All "4" versions are tri-fold, all hardware included, install in 20 minutes or less, NO drilling required, and are water tight.
All pieces, parts and components are guarenteed for life, the material is guarenteed for 7 years.
Torza Top - Traditional Vinyl -
$399.00 Delivered
Torza Premier - Convertible Top Material
$499.00 Delivered
Hard Hat - Traditional Vinyl Cover with a HARD underlayment
$749.00 Delivered
Hard Hat Premier - Convertible Top Material with a HARD underlayment
$859.00 Delivered
Please email or call me to purchase or for additional information
hwc_1@ameritech.net
937.231.7943
Torza Tonneau Guy is offline   Reply With Quote
Old 04-25-2006, 12:05 PM   #10
LATEOTT
ROC Rank: Turkey
Well I think it's great that ROC got a new sponsor, but your prices would have to come down significantly to be a service to owners here.
LATEOTT is offline   Reply With Quote
BB code is On
Forum Jump
Tonneau Cover Companies patr_1_8 Accessories 171 08-22-2008 09:50 PM
Has anyone seen a picture with a tonneau cover patr_1_8 Accessories 16 01-08-2008 10:06 PM
Again tonneau cover - happy? amazonEX-L Accessories 52 07-21-2007 11:12 AM
Bed extender and Honda tonneau cover... Nicholas Accessories 4 07-15-2006 12:20 PM
Ridgeline Tonneau cover patr_1_8 Accessories 19 04-25-2006 10:42 AM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
