| Notices |
#1 |
ROC Rank: Freshman
2008
RTX
Steel Blue / Gray Join Date: Jan 2012
Subwoofer enclosure bandpass??
I just was doing my pioneer nav install and found out my stock subwoofer won't work any more guessing that was the second plug that was not hooked into the aftermarket harness. So useless sub now, I have extra subs and amps from my last Honda so here is the main question has anyone built a bandpass box with 2 10's ? Or maybe another idea? Thanks in advance
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: 4k Comma Club
2006
RTL
Other Join Date: Jul 2009
Re: Subwoofer enclosure bandpass??
Wow! is it worth it? Ported boxes are hard enough already. I am aware of some members with single ported boxes, one I can recall, I am sure there are some more, but not dual bandpass ones that I am aware of.
Just knowing the fact that bandpass boxes sound really bad with some types of music it is something I would not be interested in doing but I would be interested in just knowing if you can build one and you post pictures here. Subthump makes boxes for under the rear seat, down fire ones. Or you can go with just a single MDF box that replaces the factory one, with a an SQ10 shallow sub, that is the only option to keep a factory look and that is made by Elemental Designs If your HU has the 5th and 6th channel rcas for the sub, all you need is an amp for it, but you will not be able to drive it with more than 40 watts. Hopefully other members can suggest other options, I think I covered all of them, and sorry to disagree about a bandpass box option.
#3 |
ROC Rank: 2k Comma Club
2007
*Former Ridgeline Owner
Nimbus Gray Metallic Join Date: Sep 2010
Can't you wire your OEM Sub into the Pioneer?
Leather, Navigation & Moonroof > 245/70 17 Toyo "Open Country" A/T Boots! OEM Steelies 245/70 17 Winter Boots!![]() My other ride is my Bicycle! |
#4 |
ROC Rank: Freshman
2008
RTX
Apparently not without a 40-50 watt amplifier.
#5 |
2006
RTL
A $30.00 motorcycle amplifier maybe?
Let us know what your plan is, unless an owner posts a bandpass box. There was a member that removed the center console and placed a dual sub box there, but I do not remember if it was a sealed, ported or bandpass, I just remember he had set up to use only one sub if he wanted. |
#6 |
ROC Rank: Freshman
2008
RTX
I'm going to try building my own box not sure what yet but will post when I'm done
#7 |
ROC Rank: Junior
2009
RTL
Nimbus Gray Metallic |
i'm curious to see how a shallow depth band pass box would turn out, just not curious to hear it
![]() 09 RTL Grillcraft black grill, Nokya 7k Stage II Lighting (Fog, H/L, and DRL), K&N Drop In, Gibson Exhaust, Sony XAV-62BT, JL Audio 10WX-4(2) in Custom Enclosure, Kicker KS525(4), PA CPT2-900, PA PC1.5F Capacitor, LEDGlow Million Color Interior Kit |
#8 |
2006
RTL
Steel Blue / Gray Join Date: Nov 2005
Bandpass boxes are hard to build and even harder to design. The most common box has a sealed rear chamber and a ported front chamber. I do not think you can build a good one without design software.
Bandpass boxes are also large. The only sound advantage is potentially higher output over a narrow frequency range. Small potential advantage for the compromises required. A BP box with two 10 inch subs could easily have a 1.5 cu. ft rear chamber and a front about that size. Do you have 3 cu. ft. to work with in the Ridgeline?
2006 Steel Blue RTL 1997 Acura NSX-T |
#9 | |
2007
RTL
Nimbus Gray Metallic Join Date: Dec 2009
Westin chrome tube steps, AVS vent visors, AVS bug shield, bed extender, carpeted trunk mat, blue LED interior switches, LED interior/exterior lights, Weathertech floor mats, Extang Trifecta soft tonneau cover, 5000k headlight bulbs, Pioneer AVH-P4400BH bypassed head unit, Metra Axxess ASWC, Jensen Carbon 65C components, Jensen Power 400 2ch bridged amp, 10" Boss Onyx shallow sub in custom behind-seat enclosure, FatMat sound deadening, Koolertron backup camera |
#10 |
2006
RTL
wrong thread cant edit
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| Will this subwoofer enclosure fit? | gnomeone | Mobile Electronics | 11 | 05-27-2008 03:16 PM |
| The Next SubWoofer Enclosure | crj_lll | Mobile Electronics | 35 | 08-25-2006 01:51 PM |
| Dual Subwoofer Enclosure | ridgeline42 | Mobile Electronics | 20 | 06-15-2006 09:54 AM |
| Dual Subwoofer Enclosure | EzRider | Mobile Electronics | 12 | 02-02-2006 04:51 PM |
| Custom Subwoofer Enclosure | ebass922 | Mobile Electronics | 5 | 01-06-2006 09:01 AM |
