Taking the Mystery Out of the Maintenance Minder System - Page 2 - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 06-24-2007, 07:49 PM   #11
McRidgeline
ROC Rank: Sophomore
2007 RTL
Dark Cherry Pearl
McRidgeline's Avatar
Re: Taking the Mystery Out of the Maintenance Minder System
Alrighty then... found the answer to my own question through another post on the awesome ROC. Disregard my earlier question on 'how to reset' the MM. It pays to read the Owners Manual AND search the ROC! Thanks!
McRidgeline is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-24-2007, 09:27 PM   #12
theLine
ROC Rank: Sophomore
2006 RTS
Billet Silver / Gray
theLine's Avatar
[QUOTE=Webwader. When the oil life reaches [B]15%[/B], youíll also see a two-part maintenance item code. This code tells you what items need servicing when you have the engine oil replaced. The first part of the code is the main code. Itís either A or B, never both. /QUOTE]
So, would it be accurate to say that if I change the oil before it reaches 15% then I will never see the additional A and B codes. Because I never have. I've asked the question before but you may have finally explained why.
I bought my Ridge used from a Honda dealer. It had 20K miles and the dealer had serviced it and reset the MM. At 25K and 30K I changed the oil and reset the minder. I don't recall the oil life percentage but it was probably not down to 15%. So, is that why I never see these additional A and B codes people talk about?
'06 Silver RTS, fully modded (trailer hitch and stick on convex mirrors). Envy me.
theLine is offline   Reply With Quote Quick reply to this message
Old 06-25-2007, 12:46 PM   #13
BillB
ROC Rank: 2k Comma Club
2008 RTS
Steel Blue / Gray
BillB's Avatar
Unfortunately, you are correct. You need to get a better history from the dealer you bought your RL from as to exactly what service they did to your truck and if any TSBs were applied in its prior ownership if that can be determined. At 15,000, the most important non-oil change service that should have been done was the first changing of VTM4 fluid. After that first change, this fluid does not need changing until the 45,000 mark unless you do towing and /or other severe condition driving and then it is on an every 15,000 cycle. Another important early service is the engine air and cabin filter replacements and that should be done around 1 year of use or in the30,000 range if you are a heavy mileage driver.
BillB is offline   Reply With Quote Quick reply to this message
Old 06-25-2007, 08:57 PM   #14
theLine
ROC Rank: Sophomore
2006 RTS
theLine's Avatar
Thanks BillB. I appreciate you taking the time to post the explanation. Although I'd read about the A and B codes in the manual I was mystified as to why they never showed up on the minder like people have described. Thumbs up!
Maybe it's a bad assumption but, since it's a Honda certified vehicle, to 100K miles, I figured Honda is keeping an eye on the dealer to make sure they (Honda) don't have to cover unnecessary repairs. I had the drivetrain fluids changed at 30K, just in case
Old 12-10-2008, 09:23 AM   #15
Redman
ROC Rank: Freshman
2008 RTX
Steel Blue / Gray
Smile Re: Taking the Mystery Out of the Maintenance Minder System
Originally Posted by McRidgeline View Post
Okay, maybe this is a stupid question, but I thought I'd ask as 'the new guy' and learn something.
If you change the oil yourself, or whatever maintenance is recommended by the Maintenance Minder (MM), how does the MM know that the Maint. has been performed and reset itself? Or do you reset that yourself through the 'reset' function, etc.? (Maybe I just haven't gotten far enough through the Owner's Manual!!!) Thanks!
Keep reading in the owner's manual!
It gives resetting instructions that amount to holding the reset button down ubtil the display resets. - 10 to 13 seconds. It is that easy.
Redman is offline   Reply With Quote Quick reply to this message
Old 07-05-2009, 08:28 PM   #16
KMVET
ROC Rank: Senior
2009 RTS
Sterling Gray Metallic
KMVET's Avatar
Are the 2006 maintenance codes you provided applicable to 2009 vehicles?
Snipers; assistance from a distance.
Badgeless 09' Sterling Grey Metallic RTL, Custom Leather, OEM Door Edge Guards, OEM Foglights, AVS Hood Deflector, AVS In-Channel, Visors, Tint, Rear Mud Flaps, Taillight Garnish, GrillCraft Black Upper/Lower Mesh Grill, V-LED's interior lights, SportWing moldings, 5S Dude license frame, Super Bumper
KMVET is offline   Reply With Quote Quick reply to this message
Old 07-06-2009, 05:53 PM   #17
Mitchie
ROC Rank: Junior
2006 RTL
Formal Black
Mitchie's Avatar
Most likely, but all the maintenance items are listed in the owner's manual.
06 EX-L Navi, back up camera (self installed) factory fog lights (modded), bug deflector, Torza top hard hat, running boards. Custom K&N intake, Magnaflow exhaust, 22" Paladin wheels w/Hankook tires. Now AVP ventshades and K2 azzera tail lights. More to come....
Mitchie is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 02:21 AM   #18
gear jammer
ROC Rank: Freshman
2006 RT
Formal Black
Does the MM take in to account for what kind of oil I use? I've been told synthetic lasts longer than conventional. I've never used synthetic, so I can't attest to that one way or the other, it's just what I've heard. I'm sure others have heard that too. If it is true, then would the MM give me more time to change the oil, or does it just assume I'm using conventional?
gear jammer is offline   Reply With Quote Quick reply to this message
Old 06-23-2010, 06:35 AM   #19
dk miller
ROC Rank: 1k Comma Club
2007 RTX
Dark Cherry Pearl
dk miller's Avatar
No, the MM does not know what brand, type, or viscosity of oil you put in the motor. It is programmed assuming you have complied with the manufacturers requirements.
Synthetic oils are fine lubricants and have better flow characteristics in cold temperatures. Don't fall for the extended drain interval hype. These oils should be changed out the same as any others.
dk miller is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 07:01 PM   #20
PATCH
ROC Rank: Freshman
2010 RTL
Dark Cherry Pearl
So, I'm at 38K and my RTL is displaying B136 for maintenance soon. Does this mean I need all of the following?
B Replace the engine oil and the oil filter, rotate the tires, inspect the front and rear brakes, check the parking brake adjustment, and
inspect several other items listed in the O/M.
Subcode What It Means
1 Rotate the tires.
3 Replace the transmission fluid and transfer fluid (if equipped).
6 Replace the rear differential fluid (if equipped).
PATCH is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
FYI - Engine Light VTEC System Mystery (& 4WD lost) Dnick Under The Hood / Performance 9 03-28-2014 09:02 PM
Honda ASV-3 Safety Info. twinjogger The Ridge - Off-Topic Discussions 9 10-29-2010 05:26 AM
Maintenance Minder B-6 RRPRTS Under The Hood / Performance 60 12-27-2005 02:37 PM
New Acura RL "Safety/Performance Extreme" twinjogger Miscellaneous/General Honda Ridgeline Discussions 4 08-18-2005 03:35 PM
Navigation System Anomalies Lifesaver1 Mobile Electronics 10 07-15-2005 08:57 AM
