Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 03-24-2005, 04:46 PM   #1
Matthew Dworman
ROC Rank: Stuffing
2006 RTL
Billet Silver / Gray
Strange question....
Hi guys,
this one is gonna sound a bit strange, but here goes:
I'm a vollunteer firefighter and I need to install a siren in my ridgeline. I've done this in several cars and trucks before, but here's my dilemma with the ridgeline:
I can not find an access hole through the firewall. Most cars and trucks have a hole with a rubber grommet that has some wires running through it. Honda has done such a good job at routing and hiding it's wiring that I can't find a way from the engine compartment into the passenger compartment. I only need to run 4 wires through - so not a big deal. I tried removing the glove box because that's usualy the best place to start, but no luck back there.
Any advice? Are you of you a Honda tech that might know the answer here?
Thanks in advance,
Matt
Matthew Dworman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-24-2005, 05:02 PM   #2
H345
ROC Rank: Stuffing
2006 RTL
White / Beige
Re: Strange question....
Follow the main harness at the circuit box back to the cab .
H345 is offline   Reply With Quote
Old 03-24-2005, 06:07 PM   #3
delphi7x10
ROC Rank: Turkey
Matt,
If you are not installing fog lamps, why don't you use the connecters made for them, that way you have an under the hood fuse, and all you need to add is the under dash switch.
The instructions are here.
http://www.handa-accessories.com/rid.../foglights.pdf
If you are installing them, well then I dont know what to say, keep looking there is bound to be a place.
Good Luck
Originally Posted by Matthew Dworman
Hi guys,
Thanks in advance,
Matt
delphi7x10 is offline   Reply With Quote
Old 03-25-2005, 09:10 AM   #4
Matthew Dworman
ROC Rank: Stuffing
2006 RTL
Hi H345 - That's the first thing that I looked at. The main harness goes into the dash behind the instrument cluster which I don't really want to take apart to access from the inside....
Good thought though.
Matt
Old 03-25-2005, 09:14 AM   #5
Matthew Dworman
ROC Rank: Stuffing
2006 RTL
Originally Posted by delphi7x10
Matt,
That's a pretty neat idea. Unfortunately, it requires special connectors which although I'm sure I can special order as separate from the foglight kit would preclude to be dificult. Also, the connections run through a relay which would require my headlights to be on and on in the low position. That's not a big deal, but I'm installing "wig-wag's" which alternates high-beam and low beam on either headlight which I fear would not permit the relay to funtion.....
Thanks for the input.
Matt
Old 03-25-2005, 01:27 PM   #6
delphi7x10
ROC Rank: Turkey
Matt,
Here is another idea, call American Honda customer service, my guess is they would love to see a Ridgeline used this way, and would have someone who knows get back to you. It would make great PR for them, and could sell some extra Ridgeline, and allit will cost you is a phone call.
Try them and let us know how you make out.
Old 03-29-2005, 12:16 PM   #7
Mr Manxter
ROC Rank: Turkey
2006 RTL
White / Beige
Mr Manxter's Avatar
Matt, I installed wires/harness for the WigWags and the Whelen siren through the rubber grommet above the accelerator pedal. I pulled power from the switched accessory outlet on the center console and mounted the Whelen within the center console (out of sight). The switch for the WigWags is between the heated seat switches.
So nothing is seen if you sit inside or look through the windows
White RTL ~ Sunroof ~ Navigation
Mr Manxter is offline   Reply With Quote
Old 03-29-2005, 12:23 PM   #8
Matthew Dworman
ROC Rank: Stuffing
2006 RTL
That sounds awesome. Can you send me an e-mail explaining a bit more in detail how you did it? I assume you removed the center console, etc. What did you use for a switch? Any pics would be appreciated as well:
matthewd@barrelguard.com
Thanks
BB code is On
Forum Jump
Oil and filter question, please... Nicholas Under The Hood / Performance 116 04-26-2006 07:47 AM
Wheel Flare question TheRidgester Exterior 3 07-11-2005 11:14 AM
Question about visor for installation of LCD laserfan Mobile Electronics 5 04-16-2005 08:14 AM
Question please... Nicholas Accessories 1 04-03-2005 07:02 PM
Here's a strange question: Matthew Dworman Miscellaneous/General Honda Ridgeline Discussions 0 03-24-2005 04:50 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
