Bazooka Tube - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Mobile Electronics
Notices
Thread Tools Display Modes
Old 01-27-2006, 08:19 PM   #1
Jebario
ROC Rank: Freshman
2006 RTL
Nighthawk Black / Beige
Bazooka Tube
Anyone put a Bazooka tube under the back seat yet? If so what size?
Jeff
Jebario is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-27-2006, 08:26 PM   #2
mugen1
ROC Rank: 1k Comma Club
2006 RTL
mugen1's Avatar
Re: Bazooka Tube
A 10 inch will not fit. I tried the other day just for fun. The 10 inch ones have an outer dimension of 10.3 something inches. You can barely fit something 10 inches under the seat - in the spot where there is an indent in the plastic at the bottom of the seat. Too bad, because the new Bazooka tubes are not that shabby. People make fun of Bazooka Tubes, but for the convenience and price, they can't be beat. I think the 8 inch models are stretching it as far as sound quality is concerned. Then again, I haven't heard one in an RL. However, it would still be miles better than the stock subs.
mugen1 is offline   Reply With Quote Quick reply to this message
Old 01-27-2006, 10:12 PM   #3
blueridge33
ROC Rank: Sophomore
2006 RTL
Steel Blue / Gray
Re: Bazooka Tube
Abilify...........
blueridge33 is offline   Reply With Quote Quick reply to this message
Old 01-27-2006, 10:56 PM   #4
mugen1
2006 RTL
mugen1's Avatar
Re: Bazooka Tube
Tried that, but pot laced with Crystal Meth seems to do the trick................
BTW, we grow the best here. Called BC Bud. Ask for it by name.
Old 01-27-2006, 11:47 PM   #5
noasridge
ROC Rank: Freshman
2006 RT
Re: Bazooka Tube
I had an 8in it sounded ok. but i don't recommend it
noasridge is offline   Reply With Quote Quick reply to this message
Old 01-28-2006, 03:15 PM   #6
TCW
ROC Rank: Freshman
Re: Bazooka Tube
I was not impressed with the stock sub so tried a couple of experiments. I had all these parts already, 8 inch Bazooka EL – passive model (98 model), 10 in Bazooka Reference Series (RS) – passive model (also a ’98 model), a US Acoustics 300 watt amp, a high-level converter and lots of wiring. I also had access to a newer 10-inch RS Bazooka that my brother had put in his Wakeboard boat.
I first tapped into the sub’s wiring behind the back seat before it went into the enclosure. From there, to the high-level converter, then RCAs to the amp (under passenger seat) then back to factory sub. Surprisingly the factory sub handled the extra clean wattage and sounded a lot better. So I wondered how the 8 and 10 inch Bazookas would sound. The 8 inch EL sounded much better than the stock sub and fit under the seat. But for poops and giggles, I tried the 10 RS, which sounds superb. It has more than adequate output (you can feel your hair moving when cranked up) and good extension, with a tight-accurate response. It wedges nicely between in tightly but the 40% split seat has to be raised. When the dog comes with us we put the seat down and move the sub in front of the seat. When we need to use the back seat for humans we move the 10 incher out and put in the 8 inch EL, that’s been waiting happily in the trunk for such an occasion. Also, I found that the newer RS Bazookas (passive models) can output more than the older versions but at the cost of sound quality. The new models have stiffer cones with large rubber surrounds, two voice coils, and can handle lots of wattage. The result, though, is lots of air moving but a bit one-notey/flabby sound. If you want to make a lot of noise, a new 10 RS Bazooka with a high quality, high watt amp can do it. I, however, prefer the quality sound, which is many decibles ,more than the stock sub. Also, the models with the built-in amps are not nearly as potent as the passives attached to decent amplification.
TCW is offline   Reply With Quote Quick reply to this message
Old 01-28-2006, 05:58 PM   #7
Ultra-HOG
Senior Member
2006 RTL
Ultra-HOG's Avatar
Re: Bazooka Tube
TCW or others that have worked with bass tubes and/or the stock sub, where did you gain access to the stock sub wire? Can it be done without removing the back seat? I have an old 8" amplified sub that I want to experiment with but have not yet.
Ultra-HOG is offline   Reply With Quote Quick reply to this message
Old 01-28-2006, 06:30 PM   #8
TCW
ROC Rank: Freshman
Re: Bazooka Tube
It probably can be done but I don't know how. I got to the wires by following the back seat removal instructions pdf from Collegehillshonda.
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
8" Bazooka Tube ebass922 Mobile Electronics 3 01-07-2006 01:34 AM
Westin tube steps ProHonda Accessories 3 12-30-2005 03:26 PM
Missing tube on my engine? vertrkr Under The Hood / Performance 11 04-28-2005 10:58 PM
