How to get better gas mileage with your Ridgeline - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Miscellaneous/General Honda Ridgeline Discussions
Notices
Thread Tools Display Modes
Old 02-10-2006, 08:08 AM   #1
truckfan
ROC Rank: Freshman
Ridgeline Owners Club members,
Here's how to get better gas mileage with your Ridgeline.
This information (with my formatting) comes directly from the FTC & EPA web sites.
Thanks to cismo for providing the link.
There are numerous no- or low-cost steps you can take to combat rising gas prices.
The most important place to start is at the gas pump;
buy only the octane level gas you need.
All gas pumps must post the octane rating of the gas under the FTC's Fuel Rating Rule.
Remember, the higher the octane, the higher the price. Check your owner's manual to determine the right octane level for your car.
Here are some additional tips from the EPA to help you get better gas mileage.
I. Drive more efficiently
1) Stay within posted speed limits.
The faster you drive, the more fuel you use. For example, driving at 65 miles per hour (mph), rather than 55 mph, increases fuel consumption by 20 percent. Driving at 75 mph, rather than 65 mph, increases fuel consumption by another 25 percent.
2) Use overdrive gears.
Overdrive gears improve the fuel economy of your car during highway driving. Your car's engine speed decreases when you use overdrive. This reduces both fuel consumption and engine wear.
3) Use cruise control.
Using cruise control on highway trips can help you maintain a constant speed and, in most cases, reduce your fuel consumption.
4) Anticipate driving situations.
If you anticipate traffic conditions and don't tailgate, you can avoid unnecessary braking and acceleration, and improve your fuel economy by 5 to 10 percent. In city driving, nearly 50 percent of the energy needed to power your car goes to acceleration. Go easy on the gas pedal and brakes. "Jack-rabbit" starts and sudden stops are wasteful.
5) Avoid unnecessary idling.
Turn off the engine if you anticipate a lengthy wait. No matter how efficient your car is, unnecessary idling wastes fuel, costs you money and pollutes the air.
6) Combine errands.
Several short trips taken from a cold start can use twice as much fuel as one trip covering the same distance when the engine is warm.
7) Remove excess weight from the trunk.
Avoid carrying unneeded items, especially heavy ones. An extra 100 pounds in the trunk reduces a typical car's fuel economy by one to two percent.
II. Maintain your car
1) Keep your engine tuned.
Studies have shown that a poorly tuned engine can increase fuel consumption by as much as 10 to 20 percent depending on a car's condition. Follow the recommended maintenance schedule in your owner's manual; you'll save fuel and your car will run better and last longer.
2) Keep your tires properly inflated and aligned.
Car manufacturers must place a label in the car stating the correct tire pressure. The label usually is on the edge of the door or door jamb, in the glove box, or on the inside of the gas cap cover. If the label lists a psi (pounds per square inch) range, use the higher number to maximize your fuel efficiency. Underinflated tires cause fuel consumption to increase by six percent.
3) Change your oil.
Clean oil reduces wear caused by friction between moving parts and removes harmful substances from the engine. Change your oil as recommended by the vehicle manufacturer.
4) Check and replace air filters regularly.
Your car's air filter keeps impurities in the air from damaging internal engine components. Not only will replacing a dirty air filter improve your fuel economy, it also will protect your engine. Clogged filters can cause up to a 10 percent increase in fuel consumption.
So it really just comes down to changing your driving habits in order to get better gas mileage & maintaining your Ridgeline.
It's not your Ridgeline's fault if you aren't getting better gas mileage.
Look in the mirror (if the drivers side had one) and see who's at fault.
You can also sometimes blame the gas blend as has been indicated elsewhere on this web site.
It definitely would help if Honda had a mpg display to help us better identify when we were driving properly to save gas.
Even my brother's Ford Expedition has one.
Hopefully Honda will have that feature in the very near future.
truckfan
truckfan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Write a Ridgeline review and help potential buyers MontanaFred Miscellaneous/General Honda Ridgeline Discussions 39 02-27-2012 08:08 PM
HOW TO install anything on the ridgeline chrissalvatore Accessories 17 04-25-2009 12:56 PM
Ridgeline takes on Baja 1000!!!! Ridge Miscellaneous/General Honda Ridgeline Discussions 14 11-17-2008 02:25 AM
Ridgeline takes on Baja 1000!!!! twinjogger Off-Roading 29 05-12-2008 05:10 PM
Honda Ridgeline Manuals truckfan Miscellaneous/General Honda Ridgeline Discussions 0 12-24-2005 04:44 AM
