Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Accessories
Notices
Thread Tools Display Modes
Old 04-18-2005, 01:02 PM   #1
Londo
ROC Rank: Stuffing
Just say NO to dealer-installed options!!!! - and to Fladeboe Honda
I got a bunch of stuff thrown into my deal, roof-rack, fog lights, backup sensors, XM radio, etc. When I got the car back after the stuff was installed, EVERYTHING Ray Fladeboe Honda touched was screwed up (and these options basically involve gutting the interior, removing bumpers, and gutting the bed). I doubt they will ever be able to get things back to factory specs. Not to mention all the rattles and squeaks the car now has.
So unless you have a long standing relationship with your Honda dealer, and know they do very good work, just say NO to dealer-installed options.
PS - Honda will not do anything about the situation. So much for Honda quality and service. And here's the list of what Fladeboe screwed up (and I know they did it because I had gone over the RL carefully before taking it in so they could fix any factory issues):
1. Holes drilled for back-up sensors WAY too big, they added funky washers to try to hide. Even with washers the sensors move around, exposing gaps through bumper.
2. Rattle in dash.
3. Hole in side bed panel missing plug.
4. Right taillight noticably crooked.
5. Drivers door-opening plasitc trim piece loose.
6. Right bed side top trim not seating properly, and clips may be smashed.
7. Right plastic moulding from bed to roof not seated properly, gap too large and uneven.
8. Rear window trim “cockeyed”.
9. Rear roof panel loose by left roof-rack rail.
10. Front bed panel to bottom panel either missing a seal or not mated properly. Can see holes that are not visible on stock vehicles.
11. Rear mudflaps missing screws and very loose.
12. Backup switch on dash doesn’t seat.
13. Left front roof channel trim piece loose.
14. Front left wheelwell not engaged with bumper, right front poorly engaged.
15. Gap in right center pillar trim at headliner.
16. FM radio reception seems poorer, check antenna cable for nicks and that connector is seated.
17. Stains on carpet at left of center dash console.
18. Fingerprints on right visor.
19. Carpet not seated properly under right front side trim, by passengers right foot.
20. Carpet under rear seat stained and has gouge marks.
21. Plastic under-shield and bumper seem loose by front tow-hook. Corresponding area on the other side is firmly attached to frame.
22. Bottom of left foglight loose. Check foglight alignment.
23. Several bedliner Torx bolt-heads are stripped. Install all new bolts in front and right side panels using hand tools, and torque to spec.
24. Cable hanging down under steering column.
25. Bumpers mated to fenders poorly. Reinstall bumper to factory specs, using a stock vehicle for comparison.
26. Left dash end-panel loose.
27. Glovebox door sticks out on right side.
28. Plastic trim panel below right rear seat loose.
29. Right rear seat release mechanism no longer works properly when in the down position.
30. Large gap under rear right roof-rail at rear roof trim panel.
Things that I fixed myself:
a. Dash facia panel not seated.
b. Rear roof panel screw-hole covers loose.
c. Green and black right F/R door seals not seated.
d. Finger print on headliner near XM antenna
Londo is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-18-2005, 02:22 PM   #2
Ridge Man
ROC Rank: Mashed Potatoes
Ridge Man's Avatar
Re: Just say NO to dealer-installed options!!!!
I had just the opposite experience, Last week I had Back Up Sensors.Trailer Hitch & Harness,Fog Lamps, Custom Grill,Hood Deflector,Door Visors,Moon Roof Visor, Running Boards,Under Seat Storage, Battery Blanket and a Bug Screen behind the Grill in front of coolers & AC Condensor. Have to say they did an excellent job zero problems. www.meidlhonda.com
But I do feel very strong that major options should be a factory install and leave the minor ones for the dealer. I hope you get your problems resolved.
Originally Posted by Londo
I got a bunch of stuff thrown into my deal, roof-rack, fog lights, backup sensors, XM radio, etc. When I got the car back after the stuff was installed, EVERYTHING they touched was screwed up (and these options basically involve gutting the interior, removing bumpers, and gutting the bed). I doubt they will ever be able to get things back to factory specs. Not to mention all the rattles and squeaks the car now has.
Ridge Man is offline   Reply With Quote
Old 04-18-2005, 03:04 PM   #3
Londo
ROC Rank: Stuffing
What is the bug screen? My RTL is only two weeks old and while inspecting the dealer's "workmanship", I noticed a lot of bugs/debris clogging the radiators.
Is this something peculiar to the Ridgeline?
Old 04-23-2005, 07:48 PM   #4
rogerstruck
2009 RTL
Sterling Gray Metallic
I agree with you about dealer installed accessories. It does not make sense to take apart a new truck to install items that could have been installed in the factory. I think its away for the dealers to make more money from you
rogerstruck is offline   Reply With Quote
Old 04-25-2005, 03:16 PM   #5
Londo
ROC Rank: Stuffing
The funny thing is that the dealer sold me the options, with installation, at way lower prices than I've seen on this board (in addition to the 5% I got off the sticker). By the time they get done redoing everthing three times they will not make any money off the deal.
But I still wish I had not gotten any of the options that require gutting the RL.
Old 04-25-2005, 03:31 PM   #6
Featser
ROC Rank: Stuffing
2006 RTL
Nighthawk Black / Beige
Featser's Avatar
I've looked at the install directions for several of the accessories and it seems Honda made some bad decisions. For example, the fog lights and XM radio require running wires, which requires major disassembly. Seems it wouldn't have cost more than a dollar or so to pre-wire these for all trucks, so all you have to do is snap in the parts. How much can 15 feet of wire cost?
I wonder if the longer design cycle for the base truck prevents knowing what kind of accessories will be in demand once it hits the market. This would explain the rather obsolete separate CD-based MP3 player (the base CD player should be MP3 compatible), and the lack of a Aux input on the base radio for an Ipod or similar. Even so, the design of accessories seems to be a year or two behind current technology.
Featser is offline   Reply With Quote
Old 04-25-2005, 05:31 PM   #7
zero
Challenged Moderator
2006 *Not a Ridgeline owner
zero's Avatar
Send a message via AIM to zero
I would imagine that future trim level packages will contain more options. They will probably include those options that require a lot of work to install (DVD, Back up camera, etc). Heck, the dealers may even beg them to do it. I can't imagine that any dealer likes to nearly disassemble a vehicle just to install an accessory.
When we have no thought of achievement, no thought of self, we are true beginners. Then we can really learn something.
zero is offline   Reply With Quote
Old 04-27-2005, 09:39 PM   #8
f12xbear
ROC Rank: Stuffing
2006 RTS
Amazon Green / Olive
f12xbear's Avatar
Send a message via AIM to f12xbear
Smile Re: Just say NO to dealer-installed options!!!!
Hello all,
although I'm new to this site I do know Honda well. The reason for the dealer installed accessories is so that it does not interrupt production. An interruption in production causes a drop in quality. As nice as it would be to have my Ridge cutom made at the factory i would rather have one that drives 300,000mi with out any major problems. The trick is to contact Honda regarding your local dealerships service quality rating. There are a little 1025 Honda service facilities in the US and all are rated on service quality. Maybe a different dealership would provide a more quality install. Also, don't be afraid to contact Honda customer service in regards to this issue. They will be more than happy to help you rectify the situation.
I hope all goes well and things are returned to normal. please keep me posted as to the outcome.
f12xbear is offline   Reply With Quote
Old 04-28-2005, 04:26 PM   #9
Londo
ROC Rank: Stuffing
Well, the last straw occured. The dealer said they were painting a new bumper for me! Yeah right, like I'm going to trust them to do a factory-quality paint job, after all the other stuff they screwed up. I've contacted Honda Customer Service. I'll report back on how they handle the situation.
If Honda resolves this adequately, I'll lay off the dealer, otherwise I'm "name'n names"....
Old 05-04-2005, 01:17 PM   #10
Londo
ROC Rank: Stuffing
Honda sucks, Ray Fladeboe sucks
Just got off the phone with Honda "customer care". They said there's nothing they can do about the butcher job the dealer (Ray Fladeboe Honda in Irvine, CA) did on my RL when installing the dealer-installed options I mentioned above.
My advice is to steer clear of the Ridgeline until they get the bugs worked out, and make installing Honda accessories easier for the lame dealers.
And run screaming away from the service department of Ray Fladeboe Honda.
BB code is On
Forum Jump
2006 Honda Ridgeline Dealer Installed Accessories T Mac First Generation (2006-present) 9 04-03-2009 03:36 PM
Loaded RTL for $32,755 Lifesaver1 Shoppin' and Test Drivin' 37 08-11-2006 11:47 PM
Dealer Cost hagerswami Accessories 3 04-18-2006 01:41 PM
Lack of Ridgeline Dealer Ads maybearidge Shoppin' and Test Drivin' 10 05-02-2005 06:33 AM
Just say NO to dealer installed options!!! Londo Miscellaneous/General Honda Ridgeline Discussions 18 04-21-2005 07:23 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
