service reminders? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Under The Hood / Performance
Notices
Thread Tools Display Modes
Old 05-14-2006, 07:18 AM   #1
eurban
ROC Rank: Senior
service reminders?
Hello- I am at the 10K mark on my Ridge and I changed my own oil for the second time at around 9800 miles. When I went to reset the oil life indicator (it was on 20% remaining) I followed the owners manual procedure but it did not reset properly the first time. Instead during the reset process I got a service due soon code (don't remember the code but it's the one that has to do with the VTM4 fluid etc) I tried again to reset the oil life indicator and this time the manual method worked. The service due soon code was not visible before I went to reset the oil life indicator and it dissappeared when I successfully reset the oil indicator on my second attempt. At the time I figured that when I actually hit the 10K mark I would see the service due soon code but it hasn't shown up yet. So I am wondering if I reset the service due soon reminder by accident or if it will still show up when the computer thinks its time to change the VTM4 fluid etc? Thanks for any thoughts.
eurban is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-15-2006, 07:05 AM   #2
shingles
ROC Rank: Senior
Re: service reminders?
those two indicators appear together the second time. So that means you reset both of them.
I beleive it's the B4 that you need to do...
shingles is offline   Reply With Quote Quick reply to this message
Old 05-15-2006, 07:40 AM   #3
BillB
ROC Rank: 2k Comma Club
2008 RTS
Steel Blue / Gray
BillB's Avatar
It is actually B6 (VTM4 maintenance) that this member is getting at about 10,000, I am getting the same now at 10,500. It also is awaiting my second oil change at <10% reading on my screen. B4 is for the spark plug change maintenance. 10,000 is pretty soon for VTM4 changeout and I personally am going to wait to 15,000 for my VTM4 maintenance. The service minder system is really only technically watching the oil life via it computer calculation formulas and all other maintenance items are clustered around the oil change intervals to make it easy to do multiple maintenances when you are in for the oil changes. The VTM4 should be good for 15,000 miles in standard use; however, Honda thought about 7500 would be the normal oil change interval, but I do not find that to be the case with my driving style and I am getting about 5500 per change period.
BillB is offline   Reply With Quote Quick reply to this message
Old 05-15-2006, 10:24 AM   #4
Rocker
ROC Rank: Sophomore
2006 RTS
Nighthawk Black / Beige
The same thing happened with me at 10k. I got the oil changed and the dealer said do the vtm4 change at 15k unless you drive in extreme situations. 10k or 10mos on a new vehicle seemed very early for a change.
Rocker is offline   Reply With Quote Quick reply to this message
Old 05-15-2006, 11:17 AM   #5
shingles
ROC Rank: Senior
It might "seem" early, but I prefer to trust Honda, the company that engineered the truck, then the independently owned dealership.
Old 05-15-2006, 05:07 PM   #6
Rocker
ROC Rank: Sophomore
2006 RTS
Hey I trust Honda I just have never owned a vehicle that needed a transmission change that fast. I have read that the oil monitoring is live while the other codes are just to group like services whether you need them or not. I would think the Honda dealer would want me to change it now rather than waiting if its the money that matters.
Old 05-15-2006, 11:42 PM   #7
RACER-X
ROC Rank: Sophomore
RACER-X's Avatar
I got something like 1a or a1 is this oil change?
racer-x
2006 Honda Ridgeline RTL white
15% Front Tint
Honda Running Boards
AEM Brute Force
ZYOXX ZX 8's w/Falken ZIEX S/TZ 04 265/40/22
36 psi cold
RACER-X is offline   Reply With Quote Quick reply to this message
Old 05-16-2006, 08:28 AM   #8
BillB
2008 RTS
Steel Blue / Gray
BillB's Avatar
A1 is only an oil change. In fact, the Honda system is telling you to only change the oil, but most of the members here have agreed that a filter change will never hurt at this point also.
Old 05-16-2006, 08:36 AM   #9
BillB
2008 RTS
Steel Blue / Gray
BillB's Avatar
Here is a downloadable version of the Maintenance Minder Code descriptions.
Old 05-16-2006, 06:23 PM   #10
eurban
ROC Rank: Senior
Thanks for the replies. . . Just to clarify, I changed my oil at 10k (first change at 5K) which happened to be at 20% oil life remaining according to the computer. There were no services codes at all displayed. When I followed the procedure to reset the oil life monitor instead of reseting it showed me something like b6 service due soon. This info then dissappeared when I tried again and successfully reset the monitor. So from what I have gathered from the replies . . . . Honda simply "bundled" the B6 service with the 2nd oil change reminder code and since I changed my oil prior to getting this code the computer showed me the reminder when I went to reset the oil life indicator. So If I understand correctly, I will not now get a B6 reminder until it comes due for the second change? I guess this is what I get for changing my oil earlier than recommended . . .Still, seems like a poor design to me! Is the computer counting my oil changes by the number oil change codes that have popped up (in my case 0 since I changed my oil before the codes showed) or is it counting the times the monitor has been reset?
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
Model
What model Ridgeline do you drive?
Color
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Insurance
Please select your insurance company (Optional)
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Honda Ridgeline Service Manual Online truckfan Miscellaneous/General Honda Ridgeline Discussions 31 03-09-2015 04:30 PM
Trailer Hitch Harness Recall shanew Recalls, TSB's and Notices 72 11-01-2006 07:23 AM
My First Service Experience at a Honda Dealer - cdepuydt Dear Honda: (Feedback Forum) 23 04-14-2006 12:07 PM
My very first Honda Service Experience 5S Dude Miscellaneous/General Honda Ridgeline Discussions 16 03-23-2006 08:56 PM
problems with service writers! windswept Dear Honda: (Feedback Forum) 10 02-19-2006 09:03 AM
