Anybody try helper springs?
12K views 7 replies 5 participants last post by  kevin_stevens
Hey Gang,
Stumbled across these in my research. As we all know, Honda doesn't recommend a WDH. I tow my trailer fine but I'd like to have a bit less back end sag when doing so.
Would something like this actually work?
http://www.etrailer.com/Vehicle-Suspension/Honda/Ridgeline/2012/CSS-1195R.html?vehicleid=201211879
Adjusts progressively to the weight of your load
Becomes stiffer when more weight is loaded onto your Honda Ridgeline
Reduces body roll and helps level your truck
Seems relatively inexpensive and easy to install. So ... obviously I must be missing something or most of you would have chimed in 'Just get some helper springs back there and you'll be fine' on my prior posts.
:act002:
#3 ·
I think those would help some. They would keep the springs from compressing too far, but I think they are more designed for springs that are already soft & sagging under normal conditions.
This is the line in the product description that really pulled me in:
"The cushioning not only absorbs shock, but also works progressively to better support weight, keeping your truck level."
As to the soft/saggy springs, the description adds this:
Designed to work with a suspension system that is in good working order
#5 ·
I put them on late this summer. To be honest I have not loaded the camper and two weeks of supplies since the install. Hauling lighter loads they did seem to slow the sag. I find no difference in the un-loaded ride/handling.
The directions say to use soap in the groove to install. Use A LOT of soap.
First side took me 45 minutes and wondering if they sent the wrong part. Second side took 15 minutes.
Yes, I was going to try those, but never got around to it. They will help with maintaining level ride height more than actual spring rate - the rate goes so high when the free coils are bound that it acts more like a bump stop. They make a range of sizes/heights and are cheap, I'd start with 1-1.5" ones and experiment. Widely available on Amazon etc.
KeS
#7 ·
That's kind of what I thought it would get me. So maybe they'll work. We'll see what happens; I'm not pulling my camper again till next spring.
