Oil Leak help - Honda Ridgeline Owners Club Forums
Notices
Thread Tools Display Modes
Old 12-18-2013, 07:11 AM   #1
Sturds
ROC Rank: Freshman
2007 RTL
Nimbus Gray Metallic
Exclamation Oil Leak help
So after arriving home last night I noticed a few dried drops of "fluid" on the ground and then after a few minutes I noticed a wet drop and dipped my finger in it and it is engine oil, upon inspecting the bottom of the engine it is thoroughly wet with oil (drips forming on engine ridges) on the side of the pan where drain is all the way to the front half of the engine (pulley side) and the frame area behind the engine near the transfer case has a through coating of oil and road grime, I checked the drain plug and its tight but have yet to get the time to clean the engine to find the source, are there any "common" locations to check for leaks, I didn't take a picture as it was getting dark, and the oil level was a little below half way on the dip stick, when oil change was done 3k ago it was topped off. I would appreciate any help.
Sturds is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-18-2013, 07:38 AM   #2
speedlever
Moderator
2008 RTS
Billet Silver Metallic
speedlever's Avatar
Re: Oil Leak help
Fortunately (but unfortunately in your case) the J35 has been a tight engine with few leakers reported. Main seal is the first thing that comes to mind. Hope it's not that because that will be an expensive fix.
2008 Ridgeline RTS in BSM
2006 Pilot EXL-RES in BSM
speedlever is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 07:57 AM   #3
larryr
ROC Rank: 3k Comma Club
2009 *Former Ridgeline Owner
White / Beige
larryr's Avatar
Re: Oil Leak help
Some Hondas have had oil on the engine due to small hole in the oil filter after hitting road debris.
Check the oil filter - good change it might be the source.
other possible causes - pcv valve clogged - valve cover gasket leak - loose oil cap - missing dipstick.
My 2 cents - YMMV
2013 Honda CR-V Polished Metalic EX-L with Navi.
The 199 fill ups on my 2009 Ridgeline with 20.6 MPG and over 60,000 miles driven- I just had 8 wonderful years in the Ridgeline but the Electronics are too many generations behind.
larryr is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 09:51 AM   #4
cccbock
ROC Rank: Senior
2012 RTS
Sterling Gray Metallic
Re: Oil Leak help
+1 on larryr comments.
If you are noticing this since the last oil change, there is a good chance the filter is damaged or loose, or it is possible oil was spilled during the change.
You probably did this already, but I would also double check the PS level and hoses and connections. They run in this general area also and a leak would run down into this general area. It would be pretty easy to mistake a PS leak for oil by the time it hit the ground and got blown around under the truck.
Take a bright flashlight and go all the way around the engine above and below and look for "tell tale" drips, puddles, or dirty spots. Chances are if you have not smelled burning oil the leak is below the heads and exhaust manifolds. As speed mentioned, these engines are not known for gasket related (heads, oil pan, etc) leaks.
cccbock is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 11:06 AM   #5
Mt.Ridge06
ROC Rank: Freshman
2006 RTL
Steel Blue / Gray
Re: Oil Leak help
A few drops usually isn't anything to worry about...I've had a few very healthy vehicles that the seals just never seemed to prevent leaking completely. Just keep an eye on it.
Mt.Ridge06 is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 11:17 AM   #6
speedlever
Moderator
2008 RTS
speedlever's Avatar
Re: Oil Leak help
Excellent suggestions above. Keep one thing in mind... a very small amount of oil goes a long, long way... so it (the leak) may look much worse than it actually is.
Old 12-18-2013, 02:35 PM   #7
Sturds
ROC Rank: Freshman
2007 RTL
Re: Oil Leak help
Well I checked it out during the day and there appears to be no oil running from the top of the engine down, the majority of the oil is coming from where the engine mates with the transmission... rear main seal? (coincidence one just went out in a friends chevy)
See pictures below, there is oil residue back to the transfer case but the majority of it is right there at the bell housing, (see cover in second photo) it definitely is engine oil, not power steering checked level in reservoir and it has the distinct engine oil smell. Anyone heard of a rear main going in a ridge 120k miles?
*edit "speedlever" I think its a little more than a tiny leak? lol
Old 12-18-2013, 03:49 PM   #8
OwnerCS
ROC Rank: 2k Comma Club
2006 RTS
Nighthawk Black / Beige
OwnerCS's Avatar
Re: Oil Leak help
It looks like the "Rear Main Seal" leak for the 3.5 L Honda V6. If you search around you will find other Honda 3.5 V6 owners (e.g. Pilot and Ody) with the issue. It costs about $1,000 to fix. I think the Pilot owners got together found a legal solution to the issue.
2006 RTS Nighthawk Black, Honda Chrome Wheels, Rear Mud Flap, and other stuff.
Visit My Personal PhotoBucket Page Link
OwnerCS is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 03:51 PM   #9
speedlever
Moderator
2008 RTS
speedlever's Avatar
Re: Oil Leak help
There have been a few reports of rear main seals going, but they are the exception.
Personally, I'd be tempted to clean it well and try some Seafoam in the crankcase and watch it for a bit.
Old 12-18-2013, 05:06 PM   #10
Ourfarm09
ROC Rank: 4k Comma Club
2011 RTS
Bali Blue Pearl
Ourfarm09's Avatar
Re: Oil Leak help
Looks like a rear main to me.
aka Ron
U.S. Army (retired) , ASE Certified
AVS ventvisors, ROC decal,
Ourfarm09 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Anyone have an oil leak yet mentallyabused Miscellaneous/General Honda Ridgeline Discussions 30 04-08-2014 05:50 PM
Oil Leak audiocr381ve Problems & Issues 14 06-25-2012 07:31 AM
Oil Leak...HELP!!! Redgrappler Under The Hood / Performance 11 08-05-2009 11:23 AM
Oil Leak JuiceGoose Problems & Issues 0 07-03-2007 07:20 AM
Oil Leak 25 Year Honda Owner Miscellaneous/General Honda Ridgeline Discussions 3 08-13-2005 06:20 AM
