Honda V6 Rear Main Seal Leak Solution - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline > Problems & Issues is the premier Honda Ridgeline Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
Old 12-19-2013, 06:58 PM   #1
ROC Rank: 2k Comma Club
2006 RTS
Nighthawk Black / Beige
OwnerCS's Avatar
My second Honda V6 OEM rear main seal is requires replacement after approximately 65,000 miles. The first real main seal failed at approximately 65,000 miles. For this replacement, I aim to use a higher quality seal than the ones used by the Honda dealer. For cars that I run at SCCA AutoX racing events, I've received excellent service from oil seals made by a company named Federal-Mogul under the National Brand.
Note: I am a loyal Mobil One synthetic oil user. I do not see a reason to change my oil brand or to use an additive when two Honda V6 OEM seals have failed at approximately the same mileage.
The Good News
A new Federal-Mogul National brand rear main oil seal can be purchased from our sponsor Rock Auto for $13.45.
As you can see at Rock Auto site, the National oil seal cost a few dollars more than other brands, but in my opinion they are well worth the additional cost.
National Oil Seals by Federal-Mogul feature the following:
-> A proprietary RediCoat sealant to eliminate bore leakage.
-> Patented lay-down sealing lip design ensures long life in spite of extreme temperatures, shaft imperfections, shaft/bore misalignment and excessive shaft thrust or movement.
I plan to get my local Infiniti master tech to do the replacement. He goes out of his way to use the best parts available for repairs at his shop.
2006 RTS Nighthawk Black, Honda Chrome Wheels, Rear Mud Flap, and other stuff.
Visit My Personal PhotoBucket Page Link
OwnerCS is offline   Reply With Quote Quick reply to this message
Sponsored Links
Old 12-19-2013, 07:26 PM   #2
2006 RTS
Steel Blue / Gray
northernlights's Avatar
Re: Honda V6 Rear Main Seal Leak Solution
How unfortunate. Don't like this seal stuff showing up lately. Good luck with fix and all will be fine. And have a Merry Christmas.
Truxx Lift, Michelin AT/2's, Garmin GPS
northernlights is offline   Reply With Quote Quick reply to this message
Old 10-23-2015, 03:07 PM   #3
ROC Rank: Freshman
2007 RTL
Formal Black
Guys, replacing the PCV valve solved my RMS leak on my 07. Please see post #23 on this thread:
ThinAir3D is offline   Reply With Quote Quick reply to this message
Sponsored Links
Quick Reply
Register Now
User Name:
Confirm Password:
Email Address
Email Address:
Model Year
What year is your Ridgeline?
What model Ridgeline do you drive?
What color is your Ridgeline?
Can you spell?
What letter in the alphabet is the fifth character of the word "Honda Ridgeline"
Please select your insurance company (Optional)
Human Verification
You may post new threads
You may post replies
BB code is On
Forum Jump
Front Main Seal or Other Leak r-squared Problems & Issues 99 11-26-2015 08:13 AM
Rear main seal leak - A/T removed! Alaskanyukon Problems & Issues 10 02-22-2012 06:36 PM
Rear Main Seal customcracka Problems & Issues 12 03-05-2011 04:48 PM
2007 Rear Main Seal Howie1014 Problems & Issues 0 01-26-2010 07:52 PM
Rear Seal Leak VTM to Drive Shaft-anyone else? Machog Miscellaneous/General Honda Ridgeline Discussions 7 06-26-2009 06:50 AM
