pulling a tree stump - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Miscellaneous/General Honda Ridgeline Discussions
Notices
Thread Tools Display Modes
Old 06-20-2006, 09:40 PM   #1
Nick
ROC Rank: Sophomore
2006 RTL
Steel Blue / Gray
Did some digging around a small but mighty tree stump. Cut a few roots with the chainsaw, and hooked up the Ridge. Put er' in 2nd gear, engaged all wheels and bingo, pulled that stump right out of the ground. I must admit it took a few tries, but it finally came out.
06 Steel Blue, Moonroof, XM radio, Nav unit, Fog lights, Honda hitch, Auto dim mirror, Burtman's wood grain dash, Under seat storage sys, Honda custom grill, Custom chrome wheels, OEM backup camera........02 Honda Goldwing
Nick is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-20-2006, 09:46 PM   #2
cdepuydt
ROC Rank: 5k Comma Club
2006 RTL
Billet Silver / Gray
Re: pulling a tree stump
Ahhhh, man, you shoulda taken some pics and posted them!!!!
Golf and Sex - Two things you don't have to be good at to enjoy.
RTL w/Nav and Sunroof, Running boards, Bug deflector, Retrax Tonneau Cover, OEM Hitch, Auto-Dimming Rear View Mirror, Weathertech Floor Mats, OEM Foglights w/Painted Bezels, OEM Side Door Protectors, '10 Pilot Touring Wheels, Kumho Road Venture KL61 Tires (New in Oct. 2012.), and Figs Hood Prop Kit.
cdepuydt is offline   Reply With Quote
Old 06-20-2006, 09:55 PM   #3
Sunshine Ridge
ROC Rank: Freshman
2006 RTS
Steel Blue / Gray
Send a message via AIM to Sunshine Ridge
You also should have put it in 1st gear not second. the VTM-4 will prevent it from spinning tires, and you would have gotten it out muuch easier than in second gear.
Current Vehicles
2006 Ridgeline Rts | 1997 Civic Dx
1997 Accord Ex | 2001 S200
1991 Accord Ex
Sunshine Ridge is offline   Reply With Quote
Old 06-20-2006, 10:25 PM   #4
DoctorJ
ROC Rank: Senior
2006 RTL
Nighthawk Black / Beige
DoctorJ's Avatar
Its an automatic, it will always start in 1st gear regardless of the shift setting. Once up to speed and shifts to second it will hold, but I doubt there was enough speed to get to second in this case.
DoctorJ is offline   Reply With Quote
Old 06-20-2006, 11:08 PM   #5
Sunshine Ridge
ROC Rank: Freshman
2006 RTS
Steel Blue / Gray
No, If you shift it to D or D3, it will shift through the gears up until 5th or 3rd, respectively. If you shift it to 2 or 1, it will start, and stay in 2nd or 1st, respectively. These gears are used for: 1st- pulling things, slow off-roading, because you dont want it to shift up, and lose torque and momentum; 2nd- use for situations when you don't need torque, but dont want wheel-spin. (which VTM-4 prevents wheel spin.)
Current Vehicles
1991 Accord Ex
Old 06-20-2006, 11:32 PM   #6
Nick
ROC Rank: Sophomore
2006 RTL
Steel Blue / Gray
Actually, I did uses 1st gear. The first time I tried it, I used 2nd gear, but 1st gear there after. Also, I engaged the VTM manually. I could take a picture of the stump, I still have it..........
Old 06-21-2006, 06:18 AM   #7
DoctorJ
ROC Rank: Senior
2006 RTL
DoctorJ's Avatar
You are partially correct, however again regardless of the shift position the transmision will start in 1st if standing still. If in second and again not moving it will start in 1st then shift to second and hold that gear.
Old 06-21-2006, 06:24 AM   #8
Webwader
ROC Rank: 3k Comma Club
2006 RTS
Webwader's Avatar
Sorry, Doctor J, but you are incorrect. Check your owners manual for verification. D2 locks the transmission in second gear. It does not start in 1st gear.
Honda Towing Package, Rear Splash Guards, Prodigy brake controller, Garmin 2610 GPS, Front Window Tint, Torza Soft Top. Echomaster reverse sensor step bumper
What I tow:
2005 Fleetwood Highlander Sequoia - 3,500 lb
2008 Ranger 1860 Angler w/150 Yamaha - 3,950 lb
"Things will get better as they improve."
Webwader is offline   Reply With Quote
Old 06-21-2006, 07:06 AM   #9
DoctorJ
ROC Rank: Senior
2006 RTL
DoctorJ's Avatar
Sounds like an easy way to damage the transmission.
Old 06-21-2006, 07:51 AM   #10
bigred1
ROC Rank: 1k Comma Club
2006 RTL
bigred1's Avatar
Send a message via AIM to bigred1
So you're saying your stopped at a light and it turns green, you take off and you're starting out in 2nd?
bigred1 is offline   Reply With Quote
Sponsored Links
Advertisement
BB code is On
Forum Jump
I'll Show You Mine, Now Show Me Yours/Christmas Tree 25 Year Honda Owner The Ridge - Off-Topic Discussions 33 01-03-2007 05:02 PM
Our Christmas Tree Tradition Long Gone The Ridge - Off-Topic Discussions 14 12-12-2005 11:24 AM
Smooth pulling uphill at 3000 RPMs steveberger Racks, Hitches & Towing 3 03-29-2005 12:46 PM
