| Notices |
#1 |
ROC Rank: Sophomore
2006
RT
Nighthawk Black / Beige Join Date: Oct 2005
Honda Maintenance checklists for service intervals
NOTE: This maintenance internal Honda Service checklist is from a California dealer...and may not be the same Intermediate Service check list used at your particular dealer (in your state) for this mileage service interval.
Please use CAUTION when using this list. It should be used for comparison ONLY--check with your dealer to find out particulars for your Honda make and mode. These maintenance checklists were given to us from the dealer when we purchased the truck in 06. The Ridgeline was too new to be added to the list...but you are probably safe to substitute the Honda Pilot for Ridgeline. These are MAINTENANCE CHECKLISTs for a major Honda dealer for these service intervals. Again, check with your particular dealer to see if your list is any different: 7500/22550/37500/52500 or 10000/20000/40000/50000/70000/80000/100000 miles Replace engine oil Replace egine oil filter Replace engine oil drain plug gasket Add windshield washer fluid Inspect cooling system Report on CA system Measure Brake system Wear Adjust parking and rear brake rotate tires Adjust tire PSI Evaluate alignment needs Measure tire wear Inspect all running lights Inspect exhaust system for leaks Inspect steering system for leaks Inspect axles and CV boots Inspect suspension system Inspect for oil leaks Inspect fuel lines Inspect all belts/hoses Check all other fluids: top off if necessary Lubricate all door/hood/trunk hinges Reset maintenance indicator add maintenance reminder Road test vehicle Cluctch operation Transmission operation Noises or problems on road test ****Pilot differential fluid change (Ridgeline not mentioned due to being new model. I'm assuming Ridgeline would also receive fluid change here. 2003 models: Brake fluid change at 50,000/100,000 miles and coolant change This MAINTENANCE CHECKLIST is from a major dealer in CA. Again, check with your dealer to see what services apply to your make/model. This is for the First 15,000 mile service (or 7500 mile service schedule) Replace engine oil replace engine oil filter replace engine oil drain plug gasket install MOC engine oil supplement Preform battery load test Perform charging system test Install MOC fuel system treatment inspect cooling system Report on AC system Inspect all running lights Replace windshield washer fluid Measure brake system wear Adjust Parking brake and rear brakes Rotate tires Adjust tires PSI Evaluate alignment needs Meausre tire wear Inspect wxhaust sytem for leaks inspect steering system for leaks Inspect axles and CV boots Inspect suspension system Inspect for oil leaks Inspect fuel lines Inspect all bests/hoses Clean and service battery cables check all other fluids: top off if needed Lubricate all door, hood, trunk hinges Reset maintenance indicator add maintenance reminder road test vehicle clutch operation W/A Transmission operation Noises or problems on road test S2000 inspect air cleaner-replace as needed Severe conditions: Replace A/.C pollen filter ****Differential fluid change-Pilot and S2000 I assume Ridgeline would also recieve a Differential fluid change at this interval...but it wasn't on the checklist being a new model at the time 4 Wheel tire balance 30,000 and 60,000 Mile Service for Odyssey/V6 Accord/Pilot Service (Ridgeline not mentioned due to it being a new vehicle at the time) Replace engine oil replace engine oil filter Replace engine oil drain plug gasket replace transmission fluid replace passenger compartment air filter replace brake fluid inspect cooling system replace air filter element add windshield washer fluid report on AC system Measure brake system wear Adjust parking brake and rear brakes rotate tires Adjust tire PSI Evaluate alignment needs Measure tire wear Inspect exhaust system for leaks Inspect steering system for leaks Inspect axles and CV boots Inspect suspension system Inspect for oil leaks Inspect fuel lines Inspect all belts/hoses Clean/service battery cables Check all other fluids; top off as needed Lubricate all door, hood, trunk hinges Inspect engine idle speed Reset maintenance indicator add maintenance reminder road test vehicle clutch operation W/A Transmission operation Noises or problems on road test Diffferential fluid change-Pilot Install MOC engine oil supplement Install MOC fuel treatment Inspect all running lights 60,000 miles Replace distributor cap/rotor if applicable Replace power steering fluid Replace spark plugs Recommended services Engine De-carb Service 4-wheel alignment 4-wheel tire balance Road force balance Replace timing belt (due at 60, 90, 105, 100 K-add'l cost) |
| Sponsored Links | |||
Advertisement | |||
#2 |
ROC Rank: Junior
2006
*Not a Ridgeline owner
Billet Silver / Gray Join Date: May 2006
Re: Honda Maintenance checklists for service intervals
For the life of me I could not find a maintenance schedule in my manuals like I have had in every other automobile I have had (Am I blind?)
I like the maintenance minder, but if the dealer forgets an item, I would like to be able to look at the maintenance schedule and past receipts to see if a missed item should be taken care of during my next service...
#3 |
ROC Rank: 2k Comma Club
2008
RTS
Steel Blue / Gray Join Date: Jul 2005
This is a maintenance guidelines printout from the Dealer system and helps explain how to interpret the maintenance minder and things the minder expects you to do when the codes comes up. Remember that the maintenance minder only is keeping track of your engine oil via a formula and the other service recommendations are being made as a convenience to you the owner so you do not have to make multiple appointments to get jobs done that could be done together.
#4 | |
ROC Rank: Freshman
2009
RTS
White / Beige Join Date: Aug 2009
#5 |
ROC Rank: Freshman
2007
RT
Steel Blue / Gray Join Date: Jan 2010
What was the price you guys paid for the 60k service?
#6 |
2008
RTL
Formal Black Join Date: Jan 2008
My guess is that Honda REALLY wants us to visit the dealer for all maintenance. So they make the codes much harder to interpret than we usually find in most auto manuals. You must do some work to interpret the "A-1" or "B12" codes. Not very hard to do, but much harder than we usually see in owner's manuals from the past.
Just figure out the codes, and you'll see that you can do most of the maintenance stuff yourself....even if you're a novice. Check the Search Function for most anything you'd like to know about DIY service. Just be SURE you keep all your receipts!....in case you have problems later.
Tom - 2008 Formal Black RTL with some extra stuff on it |
#7 |
ROC Rank: Junior
2009
RTL
Sterling Gray Metallic Join Date: Jan 2007
Csimo posted these a while ago...http://www.ridgelineownersclub.com/f...=16544&page=12
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| TSB on reverse lights | washem | Recalls, TSB's and Notices | 17 | 12-28-2011 09:01 PM |
| Trailer Hitch Harness Recall | shanew | Recalls, TSB's and Notices | 72 | 11-01-2006 07:23 AM |
| My letter to Honda regarding their customer "service" | Perkolater | Dear Honda: (Feedback Forum) | 66 | 08-31-2006 05:42 AM |
| Honda has every car in Indianapolis 500 | RidgeOwner3 | Other Cars, Trucks and Bikes | 3 | 05-30-2006 08:31 AM |
| 2006 Ridgeline Presentation by Dick Colliver, Exec. VP of American Honda Motor Co. | T Mac | Headlines | 0 | 01-10-2005 10:51 AM |
