inside bedside panel removal? - Honda Ridgeline Owners Club Forums
Go Back   Honda Ridgeline Owners Club Forums > Honda Ridgeline Accessories, Care and Mods > Mods, Installs and How-To's
Notices
Thread Tools Display Modes
Old 07-06-2006, 03:25 PM   #1
rbpsm
ROC Rank: Freshman
2006 RT
Nighthawk Black / Beige
Has anyone attempted to remove the bedside panel? I have 3 dents on the rear passenger fender that I need to get to and think I can get to them from behind the bed panel. It seems you need to take off the panel on top of the bed rail and also the bed panel on the back of the cab before you can take off the bed side panel.
Any info is greatly appreciated.
Thanks
rbpsm is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-06-2006, 06:13 PM   #2
CUinaRidge
ROC Rank: 2k Comma Club
2006 RTL
Re: inside bedside panel removal?
Pics are posted somewhere?? on the forum here...
Where I am not sure... try the review backup camara installs...
CUinaRidge is offline   Reply With Quote
Old 07-06-2006, 08:11 PM   #3
CUinaRidge
2006 RTL
I recall seeing one months ago.... can't find it now...
But these may help a bit...
http://www.ridgelineownersclub.com/f...t.php?p=116968
http://www.ridgelineownersclub.com/f...rt.php?p=61601
http://www.ridgelineownersclub.com/f...rt.php?p=10046
Old 07-06-2006, 08:14 PM   #4
CUinaRidge
2006 RTL
dough...bad posts... well one was lingered post on back up install..
Another was a post for leak found a pillar?? they showed the panels being removed... sorry the copy shortcuts didn't work!!
Old 07-06-2006, 08:15 PM   #5
Whaleya
ROC Rank: Senior
2006 RTL
Steel Blue / Gray
Not to sound snippy here, but there is a service manual folks can buy.
It's very worthwhile.
-W
Whaleya is offline   Reply With Quote
Old 07-06-2006, 11:34 PM   #6
bongus
ROC Rank: 1k Comma Club
2006 RTL
Billet Silver / Gray
bongus's Avatar
Send a message via Yahoo to bongus
-W
You're not being snippy...you figure a lot of the members here have spent a lot on their RLs yet they can't part with $100 for a manual that will save them a lot of grief and possibly more costly screw-ups. Go figure...just buy the manual.
What we do in life echos in eternity!
bongus is offline   Reply With Quote
Old 07-07-2006, 07:04 AM   #7
Empyrean
ROC Rank: Freshman
2006 RTL
Empyrean's Avatar
Thanks
It should literally take you under 10 minutes to remove the bedside panel. Yes, you do need to remove the back panel and the tie-downs. You will need both Torx T40 (for the panels) and Torx T50 (for the tie-downs). I would recommend not using a cordless drill to do this but rather a ratchet. My T40 bits got chewed up using my cordless drill. I believe you will have to remove the tie-downs on both sides of the truck behind the cab to remove the back-panel. It's really easy. If I remember there is a lot of room where you can push out a dent.
-AJ
Empyrean is offline   Reply With Quote
Old 07-07-2006, 08:00 AM   #8
BillB
2008 RTS
Steel Blue / Gray
BillB's Avatar
Important tip for removing the plastic rail guards on top: First pop out the small oval piece of plastic on rear of the rail cap using a tiny flat head scewdriver. Then remove the set screw you find underneath. Then slide the rail cap backwards about 1 inch until you can feel the tabs that are holding it to top of metal part of rail disengage. Then you can lift the plastic cap off safely without ripping off a tab (wish I had someone to give me this tip last month).
BillB is offline   Reply With Quote
Old 07-09-2006, 12:38 PM   #9
mugen1
2006 RTL
mugen1's Avatar
I have the manual, but would much rather get the info from those pdf files that Honda has for installing accessories. Most of what I've done was through the help of those files. They are much more friendly. Don't get me wrong, the Helms manual is like the bible and is chock full of info. I just like the setup of the pdf files.
Just go to Hand A's site and download the backup sensor pdf. Start from step 28 and finish with 34.
There's a link to Hand-A's website in the Accessories heading in the Forums screen.
mugen1 is offline   Reply With Quote
Old 07-09-2006, 12:41 PM   #10
mugen1
2006 RTL
mugen1's Avatar
Originally Posted by BillB
[B]Then remove the set screw you find underneath.
Mine was a philips screw. Another difference between a Canadian model and a USDM model?
Sponsored Links
Advertisement
BB code is On
Forum Jump
A Better Way to Detach and Reattach the Front Door Panel HSN 06/06 csimo Recalls, TSB's and Notices 0 06-30-2006 07:36 PM
iNSIDE WINDSHIELD FILM SGAUGEGUY Interior 4 05-05-2006 09:26 PM
Speaker Makes D-Side Rear Door Panel Vibrate JafaDog Interior 1 01-21-2006 08:48 PM
Door panel removal? CGM55123 Mobile Electronics 6 11-27-2005 03:34 PM
Removing the inside door panel ridgeNH Mobile Electronics 4 10-06-2005 04:47 PM
