| Register | FAQ/How To's | ROC Chat Room | ROC Calendar | Honda Dealers | Honda Club Store | Search | Today's Posts | Mark Forums Read |
| Notices |
#1 |
ROC Rank: Turkey
2006
RTL
Steel Blue / Gray Join Date: Mar 2005
Side Steps Corroding (Sorry:STEPS, not "boards")
Originally, This post said "running boards". That is not correct, I have the gray Side Steps. Also, sorry no picture available as I need a new camera.
So much for "corrosion resistant finish". I love the gray side steps on the blue truck and hope they can fix the problem someday. I have had the steps installed for 3 months (2,500 miles) and they are now corroding. Each step has a joint at the front and the back were the diff. sections are "butted" together. This is were the corrosion is starting. Both locations on each side of the vehicle are showing signs of rust/corrosion by a very small amount of "black seepage" that runs from between the joint. The gray finish is beginning to "bubble" and become brittle in two of these locations. It is not yet an eyesore (largest bubble is 1/4 inch) but possibly on its way to becoming one in a few months. The dealer offered to replace them, I just had him document it since I know another set would just do the same thing unless modified. The dealer also had a set installed on a truck that is for sale. These steps are showing signs of the same problem. This truck has been on their lot since March (loaded with accessories and nobody wants to pay the price). I will not get them replaced until I learn they are re-designed or have a better/more complete finish. It seems like they are corroding from inside the joint were there is either not a good finish or maybe it has rubbed off from friction of the pieces being pushed against eachother. For now, I may paint the damaged area or put some kind of sealant into the crack. Last edited by 06RTLNAVBlue; 05-11-2005 at 12:03 AM. Reason: mistake |
| Sponsored Links | |
Advertisement |
#2 |
ROC Rank: Cranberry
2006
RTS
Amazon Green / Olive Join Date: Apr 2005
Re: Running Boards Corroding
Are these the Black Running Boards or the Grey Side Steps?
Can you post a picture?
Fog Lights, Hitch, Bed Extender, Roof Rack, Running Boards, Rear Splash Gaurds, ROC Decal, CDC Custom Ridgeline Windshield Banner, Tinted windows, Super-White LEDs Interior and Cargo Bed, PIAA Wipers, Door Sills by 5S Dude, A12 Control Module, VR3 Reverse Cam, Plenio VXA-3000 7" display Nav unit, Torza Tonneau, Brush Guard, PIAA Driving Lights, Black Powder Coated OEM rims, BFG AT KO tires, Altezza Tail Lights |
#3 |
ROC Rank: Stuffing
2006
RTL
Redrock Pearl / Beige Join Date: Dec 2005
I am starting to show signs of the same problem after less than 2000 miles. I want to wait and see how it progresses and if Honda intends to improve or replace this item.
#4 |
ROC Rank: Sweet Potatoes
2006
RTS
Nighthawk Black / Beige Join Date: May 2005
Can the ends be removed? If you can remove the end-caps and the mounting brackets you may be able to sand blast the aluminum section and have them triple-pass powder-coated similar to the process used on sailboat parts which makes them impervious to road salts and sea spray. Also what material is used for the end-caps?
They may be covered under warranty! I would defiantly check that first.
"Let's ride while we still can." |
#5 |
ROC Rank: Stuffing
2006
RTL
Yes, they are covered by warranty. Also, I note that the Honda website does not show them as an available add-on any more. I suspect they have had some costly problems replacing/repairing others.
#6 |
ROC Rank: Ham
2006
RTL
Steel Blue / Gray Join Date: Aug 2005
I thought the side-steps were effectively recalled because of problems with them... I would check with your dealer to get refunded, find out if/when other side steps would be available, or maybe get them to be replaced with the running boards.
There are 10 types of people in this world... those who understand binary, and those who don't.
#7 |
ROC Rank: Stuffing
2006
RTL
Hadn't heard that, but it makes sense. I'll contact my dealer tomorrow. Kinda wished we'd ordered the black running boards anyway. Thanks.
#8 |
ROC Rank: Mashed Potatoes
2006
RTS
Amazon Green / Olive Join Date: Aug 2005
Any Honda accessory installed by the dealer at the time of purchase is covered by 60,000kms/3 year warranty here in Canada. I guess it is the same on your side,
good luck |
#9 |
ROC Rank: Stuffing
I bought my platinum running boards at www.phxcustoms.com and they look just like tube steps but have a better stepping area and the brackets were super easy to install. The boards are in chrome and it looks good with my billet grille and when I was the truck I just wipe them down and they clean up just like new.
#10 |
ROC Rank: Stuffing
2006
RTL
Nighthawk Black / Beige Join Date: Jun 2005
My side steps are doing the exact same thing. I took it to Honda and after an hour wait they came back and offered to replace them since the same thing is happening to the side steps on the sales manager's Ridgeline.
I was told that Honda had not resolved the issue and that they recommend trading them out for the running boards. On my particular accessory set the side steps are much more appealing and it bums me out to lose the look of the side steps.
RivaDragon's Ridgeline - Black RTL Navi |
| Thread Tools | |
| Display Modes | |
| Running Boards VS Side Steps | bellteck | Exterior | 59 | 11-22-2008 02:35 AM |
| Running Boards - Installation by Auto Body Shop | meanmachine19 | Accessories | 2 | 04-07-2008 05:34 PM |
| Running Boards - self install summary | vertrkr | Mods, Installs and How-To's | 21 | 08-16-2007 07:44 AM |
| What is the difference between running boards | delphi7x10 | Accessories | 21 | 12-11-2005 07:53 PM |
| FS: Running boards, like new, in Hawaii ONLY! | Keoni | Accessories | 4 | 04-12-2005 08:05 PM |
