1 - 1 of 1 Posts
Help - I do not have power from the fuse box to the back window wire harness in the drivers side door. What are my options? Thanks.
I have checked the fuse - swapped them out with new ones and it did not solve the problem.
I check the 7A "Back Window" fuse in the panel and even though all the windows and doors locks work (minus the back window) the fuses do not light. I turned the truck power to accessory while testing.
If I need to run a new harness, where do I order it from? How Difficult is it to install?
1 - 1 of 1 Posts
