2006 Honda Ridgeline RTS
69,500 miles
I’m the original owner
About two months ago, I noticed a puff of blue smoke when starting the truck. Over the next few weeks, I observed this happening not only on startup, but also sometimes when accelerating from a stop. It’s especially bad if the truck has been idling for more than a few minutes. Figuring this was oil, I have been monitoring engine oil and topping off since it started.
Mechanically-inclined buddy advised I replace PCV valve, but did not solve problem.
A few weeks ago, I get flashing check engine light while driving, then changes to solid with VTM light. Code reader picks up P0304..misfire in cylinder four. Check plugs…all normal except for cylinder four, which was oil-fouled. Replaced plugs, CEL off now, but still smoking as before.
2.5 weeks later, get flashing check engine light again, so I pull brand new plug from cylinder 4, which is once again oil-fouled. Replaced it again, this time it lasted a mere three days before the flashing CEL returned. Other than the oil smoke, the truck drives fine and feels powerful.
I’ve been reading this forum since this issue started. Have seen several similar issues, seems to point to a defect. Others reported solutions ranging from replacing the front cylinder head to the entire engine. Hoping it's not going to come to that, but what else could it be?
I am posting for two reasons:
1. I wanted to let everyone know that another ’06 has a cylinder four issue and 2. For those that have dealt with a similar issue, is replacing the front head the solution?
Taking it in to the mechanic tomorrow, will report what mechanic says.
69,500 miles
