1 - 2 of 2 Posts
Starting the install of the new stereo. Will be using Dyanaudio Esotar series with 3 way up front and no rear fill. The 6.5" are in the front doors now. Will need to figure out the mounting location and details for the upper mids and tweeters.
The subwoofer was a challenge due to its size. But it worked out OK. Could have made it 1/8" shallower for a bit more clearance but it will do as is. I used a heavy duty waffle cut speaker grill and then covered with speaker cloth to keep things from falling into the sub since it is mounted facing up.
I did have to modify the floor trim by about 3/4" but you would never know based on how tightly it now fits.
Discussion Starter #2 (Edited)
By the way I am NOT happy with the vinyl end plates. Does any one know where to get Honda vinyl? Will use hidden fasteners instead of screws.
Found and ordered Honda Vinyl.
1 - 2 of 2 Posts
