This old beater Civic I bought back in December 2015 has a few oddities. It began life as an automatic and was converted to a manual when the auto tranny died. Ergo, it has a different FD ratio than the standard manual tranny would have.
Manual: 4.06
Auto: 4.36
http://www.csgnetwork.com/rgpspeedcalc.html
Ergo, I would think my speed would be lower than indicated. Do I have that right?
But the previous owner put on 15 inch wheels/P195/60R15tires instead of the OEM 14s with P185/65 R14 rubber.
https://www.tacomaworld.com/tirecalc?tires=185-65r14-195-60r15
I've noticed that my speedometer is right on the money with my GPS. But when I check my GPS speed vs OBD2 speed (Torque Pro), there is typically a 2-3 mph difference in speed (OBD2 speed being less than GPS speed). And the difference seems related to speed... ie, the higher the speed, the greater the difference.
I recently noted that when I made a 45-50 mile one way trip (GPS distance), my indicated mileage was substantially lower. IE, a RT that should have been 96 or 97 GPS miles was short about 8 miles on the odometer.
All this means is that I'm likely getting much better mpgs than I thought!
OTOH, I'm puzzled why my speedometer seems accurate (compared to GPS) and yet my odometer seems way off.
Maybe using GPS distances is not an accurate way to check. And a measured 1 mile is too short to draw any conclusions.
Any suggestions how I might (cheaply) check my odometer for accuracy?
Manual: 4.06
Auto: 4.36
