Need some input, this one has me baffled...
The engine rpm and all of the lights synchronously 'pulse'. The engine cranks over well, fires right up and usually idles normally for a few seconds then the 'pulsing' starts. The longer it's left running the lower the rpms drop (at that point in the pulsing cycle).
The engine rpms don't surge, they fluctuate between normal idle speed and a few hundred rpm slower. When the engine slows, ALL of the lights dim. Every light on the truck. I know what you're going to say but increasing the rpm to 2k doesn't change the outcome. The lights and engine rpm still pulsate.
The truck ran well last week, then today... bam, a swift kick to the groin. 🤣
No previous running or electrical issues and there aren't any new codes being thrown.
I've attached a video. You can hear the engine load up and unload. When it loads up is when the lights all dim and rpm slows.
I can also smell burning rubber in the area of the serpentine belt after a few minutes of running. None of the bearings feel any hotter than the others
Could this be an Ecu issue? Wiring harness? Alternator on the way out?
Any input would be much appreciated 👍
