Driver side map light doesn't turn on when opening the door, but does work when pushing the switch. I replaced the bulbs first to rule that out and still didn't work, however, I gave it a couple love taps and it worked until after I turned the car on/off.
One suggestion I tried was to replace the actual switch with one from mouser electronics (part# SPED210200) and the light still doesn't come on when the door opens. I didn't have a socket set with me to pull the entire map light/console out, but did look up in there and noticed a lot of rust on the base plate. Is there a ground connection up there that could be corroded? The car does have a sunroof.
