1 - 5 of 5 Posts
Well it appears my three buttons may be wonky. Some times they work and other times not. Mostly Not.
I'd like to start with the fuse. Any idea on exactly what Fuse position (Number) the Homelike occupies.
Step two-Replacement. Any suggestions on a reliable solution?
Edit-And how is this thing removed?
If the fuse was blown, the buttons would never work.
Does the HomeLink light always illuminate when you press a button? If so, and the device doesn't respond, you might have interference such as recently-installed LED or CFL bulbs in the opener.
If the light doesn't illuminate sometimes, then the HomeLink module is likely defective and needs replaced.
ZRoger73,
Thanks for responding. My buttons are flaky, meaning it seems like I have to press them just right, like right in the middle for them to work. I'm thinking the contacts are bad. What's the trick of removing this and replacement?
1 - 5 of 5 Posts
