1 - 20 of 29 Posts
ROC Founder, Admin
ENGINE
Type: 60-degree Aluminum V-6
Displacement (liters/cc) 3.5/3471
Horsepower @ rpm (SAE net) 255 @ 5750
Torque (lb.-ft. @ rpm) 252 @ 4500
Valvetrain SOHC 24-Valve 3-Rocker VTEC(R)
Fuel System Multi-Point Programmed Fuel Injection (PGM-FI)
Throttle Control Drive-By-Wire
Intake Manifold Dual Stage (Aluminum)
Air Induction Fresh Air Intake
Emissions (Federal/California/Application) Tier 2 Bin 5 / ULEV-2/50 State
DRIVETRAIN
Automatic Transmission (Standard) 5-speed
Heavy-Duty Automatic Transmission Cooler x
Four-Wheel Drive VTM-4
Locking Rear Differential x
Maximum Rear Torque Transfer 70-percent
BODY/SUSPENSION/CHASSIS
Body Type Integrated Closed-Box Frame with Unitbody Construction
Body Construction Boxed Ladder Frame with Unitbody
Independent Front Suspension Type MacPherson Strut
Independent Rear Suspension Type Multi-Link with Trailing Arm
Steering Variable Assist Power Rack-and-Pinion
Heavy-Duty Power Steering Cooler x
Front and Rear Disc Brakes x
4-Wheel Anti-Lock Braking System (ABS) x
Electronic Brake Distribution System (EBD) x
Brake Assist x
Vehicle Stability Assist (VSA(R)) withTraction Control 4-Channel
Wheels 17 x 7.5 J
Tires: All-Season P245/65 R17 105S
Tire Pressure Monitoring System (TPMS) with Location and Pressure Indicators
EXTERIOR DIMENSIONS
Wheelbase (in.) 122.0
Length (in.) 206.8
Height (in.) 70.3
Overall Width (in.) (no mirrors) 77.8
Wheel Track (in.) (front/rear) 67.1/66.9
Approach/Breakover/Departure Angles 24.5 / 15.9 / 22
Ground Clearance (in.) 8.2
PICKUP BED DIMENSIONS
Length (in.) 60.0
Depth (in.) 20.7
Width (in.) (wheel well to wheel well) 49.5
Length Tailgate Down (in.) 79.0
In-Bed Trunk(TM) Volume (cu. ft.) 8.5
Heavy Duty Tiedown Cleats 6
INTERIOR DIMENSIONS
Headroom (in.) (front/2nd row) 40.7/39.1
Legroom (in.) (front/2nd row) 40.8/36.4
Shoulder Room (in.) (front/2nd row) 63.2/62.6
Hiproom (in.) (front/2nd row) 57.6/57.2
EPA Passenger Volume 112.0
Seating Capacity 5
WEIGHTS AND LOAD RATINGS
GVWR (lbs.) 6050
Curb Weight (lbs.) 4552
Towing Capacity (lbs.) 5000
Vehicle Payload Capacity (lbs.) 1549
Trailer Pre-Wiring 4-pin/7-pin
EPA MILEAGE ESTIMATES* / FUEL CAPACITY
5-Speed Automatic (City/Highway) 16/21
Fuel (gal.) 22.0
Green With Envy Moderator
I have not found any definite list yet. The pictures I have seen show at least 3 different colors: a red, a dark green, and a silver. Actually, I may have seen a white one posted on these boards but the picture was shot at night so it could have been silver.
Dark Green is awesome in person, kinda army looking. Silver and white both look pretty good, I think dark makes the features of the truck look better though. Not too crazy about the red, nothing wrong with it, I just wouldn't get it.
Dark Green Ridgeline
I agree with the above post. Although I have not seen one in person, I think that the dark green is the sharpest color that I have seen so far.
Just came across the news wire where I work. Honda Ridgeline first ever 4 door truck to earn top government crash test. 5 star ratngs for front and side impact crash tests from the NHSTA. I cant figure how to paste the story but I'm sure TMAC will pick it up. Good news. :)
Those are some NASTY crash pictures.
5 star ratings for both crash tests and for both the passenger and the driver. Very nice.
Honda Lowers Ridgeline HP !!??
Full back page ad in USA Today weekend edition (29-31 July) listed Ridgeline HP at 247 !!!
Is that the 87 octane hp rating !? and 255 hp is with 93 octane ??
Don't shoot me. I'm only the messenger.
AS far as I know, it is rated at 255 horse power on Regular grade gasoline. The ad in the paper is most likely a mistake.
It's not a mistake. The SAE horsepower testing procedure has changed. Based on the new testing procedure, the ridgeline has 247hp.
When did it change, shingles?
Well apparantly it was finalized end of march.
It's SAE standard J2723. It's voluntary but manufacturers have now started to rate their vehicals using it.
Excellent, thank you!
Yes, thanks for the correction. I was unaware of a bew testing procedure that would alter the horsepower rating.
It's actually quite interesting. If you go to vtec.net, you'll see the changes for the new acuras. One of the thing is, that the TSX now has 205 SAE certified HP. Thing is that car probably has closer to 215 of the old hp(up fron 200 old hp). But to the average consumer: "oh it's only up 5 hp". The manufacturers are going to have an interesting time marketing this stuff...
1 - 20 of 29 Posts
