1 - 3 of 3 Posts
Recently purchased a 2006 RTL it was hit on the driver side fully repaired
Three passenger doors power locks work as long as the drivers door is manually locked or unlocked looking for suggestions I've already replace the actuator on the drivers door still nothing looking for a schematic or some pointers on how to troubleshoot this problem
I'm assuming the drivers door open switch works as the domelight lights when the drivers door is open. The lock position sensor of the door lock works as it won't turn the security unless the door drivers door lock in down position
Thinking when it was hit on the side that possibly a broken wire to the drivers door actuator without a schematic I'm kind of stumped
Glad you found out what the problem was. Did you take any pics and can you post for other ROCr's to learn from?:act035:
1 - 3 of 3 Posts
