Here are the powertrain changes in 2009:
Powertrain
Horsepower and torque (increased)
Magnesium dual-stage intake manifold (previously aluminum)
Camshaft (tuned for low-end torque)
Intake valves (larger)
Starter motor (ultra-fast)
Transmission gear ratios (lower for better acceleration)
6-degree crank pulse sensor
Airflow meter within the air intake tract
Optimized engine block coolant passages
New EGR valve
Others here would know more than I, but I would think a short block swap shouldn't be a issue.
One issue that comes to mind is the temperature sensors. On the 06'-08' both are around the thermostat housing and in 09' they moved one to the lower radiator, but swap housings and should be good there.
Yes the intake needs swapped as the MAP/MAF sensors are different.
Other things may come to mind later, but that's what hits me off the top of me head...lol.
Powertrain
New EGR valve
