Additional details are now available on NHTSA's website in the Part 573 Safety Recall Report.
- 7% (8,221) of 117,445 2017-2019 Ridgelines are estimated to have the defect.
- Description of the Cause: The RVC wire harness was manufactured with a protective corrugated tubing and harness guide to help protect the wiring from stress when the tailgate was opened and closed; a zip tie was used to keep the corrugated tubing and guide in the proper position. With some RVC wire harnesses, the length of corrugated tubing inserted into the harness guide (i.e., the overlap between the corrugated tubing and the harness guide) was insufficient to provide optimal protection and the zip tie was insufficiently tightened to keep the tubing and guide in the proper position.
- How Remedy Component Differs from Recalled Component: Recalled components may contain an insufficiently tightened zip tie and corrugated tubing that is not inserted sufficiently far into the harness guide.
