I just find it confusing that Jsport will not sell the leveling kit separately, They have already spent the Design, R&D and tooling money, so they have an investment they need to recover. The other three items, tires, wheel and decals are all items that are purchased then resold twice (read: marked up twice), once to Honda, then again to the end customer. I don't see where getting Honda to install all of them is an advantage as far a getting a warranty, the tires will wear out (like any other), the wheels should not have any problems (the original MFG should warranty them) and if the decals fade, who is going to have them re-installed? That leaves the leveling kit, if it is properly engineered/designed/fabricated (which I'm sure it is), there isn't anything to wear out in spacers. Is Honda going to give you $$ credit or the four sets of tires and wheels (take offs) that you would have normally received when purchasing the Ridgeline? I doubt it, that is another chunk of money you will loose.
I would be curious to know if they have sold any of the packages yet.
