1 - 5 of 5 Posts
Target Audience
Folks like me who don't mind a one-time effort and a few bucks to have both 7-blade RV and 4-pin flat trailer connections. I have 2 'braked' trailers that need the 7-blade and a very frequently used 8ft. utility trailer w/o brakes that uses the 4-pin flat; I also 'swap' trailers of both types with neighbors.
Worth it to me to spend a few hours and a few bucks one-time for years of day-to-day convenience without adaptors.
Mine is a '19 RTL-E with OEM 7-blade socket and the socket bracket welded to the hitch; alter as needed if you have the accessory wiring/socket with bolted-on socket bracket.
Parts Used
Google the Hopkins PNs to find your best source; I found my best deal through Walmart online, $36.11+local tax w/2-day delivery 'free', YMMV.
IMO the Hopkins pieces are very high quality, fully gasketed, the harness connector is genuine Delphi with water seals
Materials Used
  • Rustoluem High Heat Ultra (satin black I had on hand that happens to be a very good match to the RL OEM hitch components)
  • Electric-connection grease for all socket pins (pouch included in the Hopkins kit)
My Basic Steps & Tips (there's endless ways to do this project, YMMV):
1. OEM socket/harness removal
  • remove two bolts then slide the socket straight down to remove from bracket
  • use a 'split-blade' trim tool to pop both the harness clip and harness connector clip out of the chassis holes
  • carefully use a tiny screwdriver to release the harness clip 'zip-lock' loop for re-use
  • remove the harness connector clip from the connector to allow the connector to separate
2. OEM socket bracket removal
  • a SawsAll w/metal cutting blade fit into the visible gap makes quick work of cutting-off the OEM bracket (3 tabs)
  • 3-1/2" angle grinder makes quick work of removing weld beads to flush-and-flat (don't repaint yet)
3. Hopkins 40975 bracket installation
  • painter's tape on the hitch bottom makes it easier to mark your location
  • the Hopkins kit includes self-drilling/tapping TEKS screws - I find it easier to install these in awkward locations by drilling a pilot hole just large enough to let the TEKS screw fit down to the start of the threads
  • centerpunch your hole locations no matter what
  • after holes are drilled, then prep the metal and spray on your touch-up paint (hand held cardboard mask makes it easy, I did 3 coats)
  • apply a thin layer of RTV to the bracket flange to 'bed' and prevent moisture trapping between the bracket and the hitch (optional)
  • if you pre-drill for the TEKS screws they are easy to start and tighten using a standard socket-driver
  • snap the socket into the bracket
4. Hopkins 40985 harness prep & install
  • attached is table for wire color correlation in my case
  • VERIFY your Honda harness wire colors vs Hopkins wire colors (correlate wire to 7-blade socket function)
  • Remember to 'stagger' your splices so they aren't all bulked-up in one place making it hard to fit the split-loom cover neatly
  • Splice in the manner you prefer - I did solder + heat-shrink splices in this case to reduce bulk (crimp connectors furnished in the Hopkins kit are likely perfectly suitable)
Now just waiting for the RedArc brake controller to arrive ...... ?
Bought a 7 pin to 4 pin adapter plug from e-trailer for my 2019 Passport. Less than 10 bucks, simple plug and play, has LEDs built into the plug to indicate light function.
Discussion Starter #5 (Edited)
Good to have options, to each their own, no worries :)
But adapters isn't the subject of this thread, please ;)
1 - 5 of 5 Posts
