1 - 17 of 17 Posts
I recently purchased a 2020 RTL-E and have been trying to decide on a hard folding lockable bed cover like the BAK FLIP MX4. I’ve watched a number of installation videos. They all show installations using rail clips to attach the rails to the bed. My RTL-E has a bed liner making the bed rails inaccessible. I must be missing something and would appreciate information from anyone who has installed this type cover on their truck. Thanks in advance....
Ed in North Myrtle Beach, SC
Your truck does not have a bedliner. Like all Ridgelines, it has a composite bed, which is a good thing. It does not have conventional truck bed rails, which is a bad thing.
Most tonneau covers, including the BakFlip, available for the Ridgeline utilize rails that attach to the anchor points along the bed wall. These come with the tonneau cover.
Covers that don't require rails are the Honda oem cover, the Undercover one-piece, and maybe the Diamondback(?).
It appears the OEM cover is my best option. Thanks for the info.
The early Honda covers had a propensity to leak quite a bit, as well as cause indentations on themselves after being left open for a while. We haven't seen as many complaints about these issues lately, so the newer ones may be better.
Be aware that the Honda cover is made by a third party. There is nothing special about it other than it forces other third-party folding tonneau mfrs to add rails to the truck. The rails still allow the trunk to open around 75-80% in most cases, and no one has complained about ease of getting into the trunk with rails installed.
If water-tightness is important to you, you might research a little further. See @phineas posts - he's done a lot of homework on tonneaus.
I bought the Honda OEM cover and you are correct. It does leak and not only at the depressions at the front of the rails. Actually, the design is such that it leaks at the two joints where it folds. Not so bad if it leaked only at the edge near the rails. It can leak anywhere across the width of the bed. It’s pretty much designed to leak. It looks nice and is secure but otherwise guaranteed to get stuff in the bed wet. Recommendation: don’t waste your money.
I bought the OEM cover as well for my 2020 RTL-E
I have had it since last day in February.
It has been in some serious rain since then.
I have noticed it leaked once and that was just a little bit at that. Not exactly a sieve.
So far I have been happy with it.
Installation issue?
My cover was dealer installed. It is part number 08Z07-T6Z-102. Is this the same cover you have? From the installation instructions it’s a fairly simple process. The instructions state clearly it’s not waterproof. Was yours dealer installed? Thanks for the reply.
I‘d also say you might want to look closely at your cover. I’ve had my OEM cover on for 8 months - simple install, did it myself - and not water proof but almost. If it’s leaking badly you might even ask the dealer to check it. Sounds like something might be wrong.
Just also noticed your part number doesn’t seem to be the most recent part number. The last digits now look like 100F released in November ‘19. Not sure which I have. That’s exactly when I purchased mine. Doubt it would make that much difference. I believe the change was for an improved latch.
It was dealer installed.
When I get the time to dig into my file on the RL I will look at the part # and post.
I have been very happy with this dealer by the way. I bought the Ceramic coating and the bed cover both installed/applied at the same time.
Folks, it takes a while for the troubles with the Honda tonneau to begin. And some units are more problematic than others. But MANY people have had these issues. @Husky1000 described the problems you might encounter very well. My experiences match his.
Adding the BAK rails to the Ridge takes no time at all to install. The only downside is you lose the top tie downs.
I have the BAK Revolver X4
Not sure what hesitation was for or the quick turnaround to go with OEM.
Banned
Just also noticed your part number doesn’t seem to be the most recent part number. The last digits now look like 100F released in November ‘19. Not sure which I have. That’s exactly when I purchased mine. Doubt it would make that Showbox jiofi.local.html tplinklogin much difference. I believe the change was for an improved latch.
Buying my truck this week (EXCITING! Gonna name her Rhonda). I can't find any local OEM place that carries tonneau covers designed for the new model. I could order one online, but that's a pain. Anyone get the factory option? Wondering if it's worth considering, despite the price ($1900 in Canada). Any opinions would be appreciated. Thanks very much.
2020 RTL-E
I went with the Bak Industries Revolver X4. Couldn’t be happier. Keeps cargo safe when closed and I can still see out the back when it’s rolled up. Things stay pretty dry on the inside too. I used the chat function on Bakflip’s website to ask about the best deal and got an great price! Easy to install, took maybe 2-3 hours but I took my time to make sure it was done right. I’d buy it again if I had to.
2020 RTL-E
404738
Ordering online means self install, but in all other ways -- especially price -- it's usually the much better way to go.
I owned the Honda tonneau. There are many people posting that they like it. But honestly, compared to several other models out there, it's a dog.
1 - 17 of 17 Posts
