Thank you all for the many helpful information on the audio upgrade threads. I have found a lot of helpful information but still have some information that that could not find. Some of information I have gathered so far are (please correct me it's inaccurate):
RTL-E & Black Edition: 540W 8-speaker system
I am thinking of the following upgrade
I have have always used Focal speakers with decent aftermarket amps and head units and they sound very good to my "not-quite-audiophile" ears. I am wondering how they would sound with the stock head unit and amps. My interest is sound quality without replacing head units or adding sound processors/after market amps, and I have no desire to rattle the neighborhood with a lot of bass.
Thanks in advance.
UPDATE 1/10/2021:
Thank you all for your suggestions and recommendations. My plan this past weekend was to put the following:
However, I noticed significant improvement after installing the Dynamat Extreme in the front door (I applied a lot including outer panel and outer surface of inner panel). I only connected the left front Focal woofer/tweeter and isolated the front speakers by turning off the center speaker & subs and fade all the way to the front. Then I shift the balance to left (Focal woofer/tweeter) and right (OEM speakers). Surprisingly, the sound improvement with the Focal PS 165FX over the stock speakers were marginal to my ears (may the Focal speakers were not broken in yet or may I should have connected to the cross-over instead of directly to the factory speaker output). The volume output of the Focal woofer/tweeter was also slightly lower than the OEM speaker (which is 20W 4ohm). Anyway, from my limited experience, the most significant sound improvement to my ears was actually from sound deadening the car doors.
So I am cancelling my audio upgrade at this time. I may apply sound deadening to the rear doors next. I am happy with the OEM sound system with sound deadening so far. If I ever want to upgrade the audio system, the next step would be a small amp and subwoofer. I probably won't upgrade the speakers unless I am adding the DSP/amp as well, which is highly unlikely.
Thank you all again for the suggestions and recommendation
- 2x front door speakers: 6.5 inch, 4ohm
- 2x front pillar tweeters 4ohm
- 1x (or 2x?) center dash speaker: 3.5in, 4 ohm
- 2x rear door speakers: 6.5 inch, 4ohm
- behind seat woofer: 8inch, 2ohm
- Front door, pillar, and center dash speakers with Focal PS 165 F3E 3-way components speakers and try to fit the 3-inch focal midrange into the 3.5inch stock location (with an inline cross over for the tweeter and directly to the midrange and woofer without going through the Focal cross-over). Will this set up work?
- Rear door speakers with Focal PC165F 2-way car speakers
- Rear woofer with Focal P20 FSE 8-inch subwoofer (4ohm) or Kicker CompRT 43CWRT81 (dual 1-ohm voice coils wired to be 2ohm, since the factory subwoofer is 2ohm. Any thoughts on these two options or any other subwoofer that I consider?
Thanks in advance.
UPDATE 1/10/2021:
- 2-way Focal PS 165FX in the front
- PS 165FX woofer in the rear (no tweeter)
- Focal P20 8-inch shallow sub (4 ohm) with a JL Audio XP300/1v2
