1 - 4 of 4 Posts
Hello: I just installed the low profile Honda air deflector (08P47 T6Z 100A) on my 2022 Ridgeline. After I installed it, I attempted to remove the "factory protection film" on the outside of the deflector (note: this is -not- the protective film you install under the brackets).
However, I can't seem to get the film off the deflector --- Before I get my razor blade out I just want to make sure there is a protective film to take off. I don't don't want to scratch it up...
Read Only
Those protective films can be a little tricky to remove. I usually lift up a corner with my thumbnail and then just peel off. If you're struggling with that technique, some 80-grit sandpaper should do the trick.
1 - 4 of 4 Posts
