2023 Honda CR-V Apparently Revealed By Chinese Government Agency
The newest compact SUV from Honda gets a third-row seat and Civic vibes.
Another Honda model with the RL front end.
I think so. Ours is a 2020. Has 26,000 miles on it and not a moments trouble.Did they get the oil dilution problem fixed in the CRV engines?
Might as well check out the Hybrid varieties too.I'll be very interested on how this update plays out. My wife has always liked (and has) the Acura RDX, but tired of the closest Acura dealer being a hour plus away. She's been looking at the CRV, Audi Q5 and BMW X3 (we have local dealers for all three). Surprisingly she's been very focused on the CRV (of course the Acura being a Honda product and trouble free helps)
Does it still have the shift lever on the dash? My wife won't buy it for that one particular reason.Might as well check out the Hybrid varieties too.
Haven't seen any official photos yet. She considers the current version to have the shifter on the dash? A unofficial pic shows buttons where the lever is now. I guess that would be a no go if true.Does it still have the shift lever on the dash? My wife won't buy it for that one particular reason.
The current gen CR-V has the shifter in the center under the radio/aircon stack. The hybrid version has the same buttons as the R/L instead of a stick.Does it still have the shift lever on the dash? My wife won't buy it for that one particular reason.
My wife was not thrilled with the shift lever location either - not sure how the push buttons would be viewed. It (shift lever look on the CRV) was one of the reasons she preferred the RDX which has the standard console mounted shift lever. Minor detail but interesting how a small item can make or break which car to go with. Hoping the 2023 CRV has a Ridgeline type set up with the push buttons on a center console.Does it still have the shift lever on the dash? My wife won't buy it for that one particular reason.
Go take her to.look at some UTVs first. A lot of them have a shift lever up on the dash, just like an Odyssey or CRV. She might think it's cool after that...My wife was not thrilled with the shift lever location either - not sure how the push buttons would be viewed. It (shift lever look on the CRV) was one of the reasons she preferred the RDX which has the standard console mounted shift lever. Minor detail but interesting how a small item can make or break which car to go with. Hoping the 2023 CRV has a Ridgeline type set up with the push buttons on a center console.
Hopefully that has been rectified with the 9-speed transmission.The Ridgeline has the great, reliable, 3.5 liter engine, but not a reliable transmission it seems, if you go by the 6-speed record Honda has.
Honda's CVT's in the last-gen CR-V and current-gen HR-V are known to self-destruct then there's the oil dilution issue in the last-gen Civic and current CR-V.The CVT + 1.5T, is utterly reliable by most all accts, compared to the ZF6, 9 speed trans in the Ridgeline.
I think it's gone way past 150k now from many owners, and there aren't reports of it failing. Looks utterly reliable.The 1.5T / CVT combo is nothing to write home about either. It will not make it past 150,000 miles.
It is not the Honda of the 1990's and 2000's.
Yes, I hope so too. But hope is different than just knowing you could rely on something through its record.Hopefully that has been rectified with the 9-speed transmission.
I don't doubt your ZF transmission knowledge. But I don't know of any "self destruct problem." Except for the very early ones. Honda is riding a very fine line with its 1.5T engine, and its efficiency, reliability. I think if you head over to the the Accord forums, and ask about failures of the 1.5T Combo, you'll get very near zero from the years 2019 to 2022.Honda's CVT's in the last-gen CR-V and current-gen HR-V are known to self-destruct then there's the oil dilution issue in the last-gen Civic and current CR-V.
The 6-speed in the 2017-2019 Ridgeline is a Honda transmission. It has lots of problems. The 9-speed in the 2020-current Ridgeline is a ZF transmission. It has been much more reliable than the 6-speed so far.
[/QUOTE
