2023 RAV4 PRIME
4646 Views 94 Replies 21 Participants Last post by  14v6
Wheel Tire Car Vehicle Hood
All I can say is wow.
Doesn't feel heavy
Engine never turns on less than 50 mph
Way way quicker on battery only than I could have imagine on battery only. This is very surprising. It really doesn't need the engine. I can see future designs giving a bigger battery and a smaller engine.
It does die off after 50
I'm going to get into a lot of trouble.:rolleyes:
When everyone starts driving EV's the govt. is going to have to intervene. Folks are going to take advantage of the capabilities and do things that you think aren't possible.
If I charge this thing up I rarely go over 30 miles so it's pretty much an EV but were down to 2 cars now so it's nice to know it can operate like a regular hybrid.
Complaints:
No Home link. I think it was there in 2022.
The Matts that were port options for $309 are carpet. I'll have to go to the aftermarket for rubber ones for this climate.
Is it worth 46k sticker in today's market? Probably. I would say the regular hybrid is all you need and the gas model only for those that do lots of highway miles. Never thought I'd get a taste of this in my lifetime.
  • Love
Reactions: 5
41 - 60 of 95 Posts
Two things I learned from the CCN videos. A lithium battery is most stable at half full. Charging it to full and not using it is bad practice. Apparently batteries have to be conditioned before they're charged so if you know your departure time Toyota has some sort of timer to take care of all of this when charging.
Of course gas going bad is an issue and ethanol free would be better to prevent rust/rot, etc. We do have ethanol free here but it's 91 octane so I'm not sure if that's the way to go. Best thing to do is drive it as a regular hybrid every once in a while. A road trip which seems routine these days would solve this without having to go to 91. I have 58 miles on the car but it says there's 8 miles left of EV so I guess regen has added some charge to the battery. It shows as slightly less than half full. I spent time sitting in the car with it on configuring the dash screen and the middle screen. Found out there's a compass in there ha ha. The old Toyota system allowed you to configure your home screen to 3 sub screens. The new setup doesn't have hard buttons anymore so it doesn't look like there's a way to configure the home screen. I love the fact that it defaults to whatever I was listening to last. With the Passport it always went to Apple music so I would have to ask Siri to play a playlist on Spotify every time the car was started.
I've barely heard the engine so I will put it in hybrid mode to get the engine circulating.
Really loving this white. Reminds me of a white Acura Integra I had which with smoked black windows. Thinking about getting some overlays to black out the chrome placards. I find all of this fun. This RAV gives you options. If it matches the regular hybrid mpg's I'll be charging it much less than I would have expected.
A PHEV will occasionally run the engine so that it uses up the gasoline over time even if there's always sufficient battery range.
Yes, a lithium ion battery is happiest sitting at a 50% charge all its life, but there's relatively little penalty for cycling between 20% and 90%. It's sitting at 0% and 100% for long periods of time that really take a toll on its capacity over time.
I set my Tesla's charge limit to 60%. I'm at about 40% by the time I finish the day's driving, so the battery hovers at around 50%. This will result in slightly longer life than cycling between 90-70%.
  • Helpful
Reactions: 1
How long does gas (with ethanol) usually last before starting to go bad ?
Gasoline generally goes bad in three ways...
1) volatility - gasoline will lose volatility over time, and this will degrade engine performance over time. Good news is that you can just add fresh gas, burn it off and get back to your original performance. Volatility can depend on fuel composition which can vary from season to season, region to region and even state to state.
2) exposure to air - the hydrocarbons in gasoline react with oxygen and form new compounds such as gum and varnish that can clog up fuel lines as well as carburetors and injectors. Oxidized gasoline can smell sour and have a dark color to it.
3) exposure to moisture - most E-free gasoline performs well as long as it doesn't get too much water contamination. If it does get water contamination, then the addition of alcohol (ethanol or HEET, for example) can help bring it back to performance standards.
However, if gasoline containing ethanol is exposed to too much water, at some point it can't absorb any more water, and you run into performance problems. Sometimes you can add additional alcohol, if your engine can handle it. Otherwise, may need to drain the gas and start fresh. Point is, you have some ability to recover e-free gasoline once it's compromised, but very little ability to recover ethanol once it goes bad.
All of that said, I've had e-free easily last a year, and ethanolized gas last for up to a year in a dry environment. Most experts seem to recommend 3-6 months, maybe even less, somewhat depending on the humidity in your environment, how protected your fuel system is from the environment, as well as temperature swings responsible for condensation if water vapor is able to get into your fuel system.
Moreover, if you purchase fuel from a filling station that has low turnover (sells less gas, so therefore has older gas in the bulk tank), the life of your fuel will likely be less.
Adding a preservative like Sta-bil can prolong the life of gasoline for up to a year. I would avoid using it past a year, though.
Modern fuel systems tend to insulate fuel from air and moisture a little better than older systems, but you still need to follow above precautions.
Getting off-topic here, but you do not want to use ethanol in an older engine or fuel system that has never used ethanol before. This isn't much of a problem in the auto industry, but is a huge problem in the marine industry, older power equipment and classic cars. The main issue here is that you have older fuel tanks that have built up crud over the years. Ethanol is a cleaner and will scrub the crud from the fuel tank walls, and that crud will then clog fuel lines, fuel filters and other components (such as fuel injectors or jets in carbs).
In the marine industry, there are a lot of older boats with built-in fuel systems. These boats are often re-powered with newer engines. The engines will run fine on ethanol, but the fuel systems on the boats can't handle it. This is why ethanol is such a huge controversy in the marine industry. Fuel suppliers in marinas offer e-free, but it comes at quite a premium cost. Just another over-inflated cost for boaters.
Sorry, I'll get off my soapbox before I really get into a rant about all of the environmental damage that ethanol has caused....
Reactions: 4
For my lawn mowers, pressure washer, and generator, I buy mid-grade and add a fuel stabilizer every time.
For my 2-cycle equipment, I use TruFuel.
My 2017 Civic Si sat for over 5 months with the same E10 fuel.
My 2019 MX-5 Miata will sometimes contain the same E10 for 3-4 months.
I don't recall ever having a problem related to "bad gas".
Reactions: 1
We love ethanol in the corn belt. Not really kidding here.
It’s actually hard to find ethanol-free. I noticed some the other day at a Caseys and it was $.40 more per gallon. So, uh, no. I will stick with the corn-flavored gas.
So putting it in HV mode makes it run a lot like the regular hybrid with the engine cycling. Stale gas won't be an issue using this mode from time to time. I suspect this will be the mode to use to get some heat during the winter months anyway. The Prime is more quiet inside than the other RAV's we have. I don't know if there's more insulation or acoustic glass but it makes the engine feel upscale. Driving around in EV with the engine off is the way to go though. Battery level is at 50% so no need to charge. Display says 9 miles of EV and something like 500+ combined. Love having options.
Reactions: 2
Phase separation in ethanol gas is a problem. Especially when used in 2 stroke and carbureted vehicles.
Reactions: 1
Doesn't feel heavy
Complaints:
I'm confused :oops:...... Isnt this a Ridgeline page???
This is a Ridgeline website with forums for many different topics including this one, which is for "other cars, trucks, and bikes".
Reactions: 1
Everything I've read said that with modern engines, ethanol is NOT harmful in any significant way. But that does not hold true for small engines or marine engines as discussed above.
Apart from the reduction in fuel economy.
Yes ethanol is less efficient. But it’s so much cheaper…hard to justify the price increase for pure gas in this area.
More inventory popping up. Most colors on the ground with more coming in that aren't spoken for. If the on the lot inventory continues to build I think 41k will be attainable with the 1k New York rebate. That would be a solid deal about 5k off MSRP. If this keeps up some of the regular hybrid trims could price out higher than a Prime SE. Even the regular hybrids aren't all spoken for now (about 80% are). I see cracks now for stuff that was unobtanium 6 months ago. So glad I was able to unload the Passport at highest offer. I had been submitting offers to CARMAX for a few weeks. That was the driver in all this.
Reactions: 2
Just loving the drive of this thing. Love the way it pulls off the line, out of turns and eats hills!! Battery now drained, time for first charge. Almost have decoupled my brain from the Honda setup except for the radio controls on the left side of the steering wheel and the Passport automatically going to park when shutting the engine off. Glad to be rid of that push button shifter and stop start. This thing is good and fun.
Reactions: 4
How many miles can you get out of the EV portion of the RAV4?
Not sure, I've been purposely trying to get the engine to come on but the battery got low enough that the engine came on to charge it at around 80 miles. It felt like the engine never came on for the first 40-50 miles or so.
Reactions: 1
So I've been impressed at the passing power and and off the line performance of the Prime. I have a spreadsheet I sometimes input data to for engine performance and headlight performance to get an idea for benchmarking. Acceleration is in with the pack for 0-60 but passing it's in its own league . Prime 50-70 was 3.4 seconds. Accord V6 was 4.2, Accord 2.0T was 4.4, the second best of all the ones I have recorded was the F-150 with the 3.5 turbo at 4.0, what a beast. I thought the regular RAV hybrid was amazing but it's number was 5.1. CX-5 was 4.6. I would think anything without a geared transmission is even faster in real life. Of course stopping is poor but handling wise I'd say it's better than the Passport was.
As far as the Passport, I haven't seen it show up on Carmax, guess it never will.
  • Helpful
Reactions: 2
2
Found some charging info from the app. Not sure what they mean because for the first charge it was supposedly empty. When I charged today it was around half full. Either way if the kWh are actuals there are some savings.
Reactions: 2
Found some charging info from the app. Not sure what they mean because for the first charge it was supposedly empty. When I charged today it was around half full. Either way if the kWh are actuals there are some savings. View attachment 437713 View attachment 437714 View attachment 437713
my wife drives a 2020 BMW X3 PHEV with a sad 20 mile range although, having said that, about 90% of her local driving is on battery. The BMW app also has a similar charging history. In the BMW app you can plug in your utilities charge per kWh to get a cost estimate of each charge.
I appreciate your posts on the Prime. That's a vehicle we were looking at to replace the X3 when it's warranty expires. However, now we may jump to a full EV as the choices rapidly expand.
41 - 60 of 95 Posts
