1 - 4 of 4 Posts
Hello, can any one help me and tell me if GoodYear Wranglers 255-75-17 tires require any big lift, or can I just get away with a 2" front leveling lift kit w/extended sway bar links kit? These will be mounted on stock 17 wheels.
From my research any lift really doesn't help fit larger tires over stock height. It's the side to side diameter where the rubbing is a issue. 255/75/17 is a tall wide tire so I'd think you run into some pretty serious rubbing with or without a lift of any sorts. I think it's almost 2" taller than the stock size and an inch wider.
No, there won't be any rubbing - but that's after you get done cutting away the fenders and other material that's in the way.
Basically, if you want a tire that big, you should mount it on something besides a Ridgeline.
Flymo
1 - 4 of 4 Posts
