1 - 7 of 7 Posts
What tires sizes do you guys have other than the stock 245/60/18? I have a 1.5” level installed and just curious about different options for going a smidge bigger using stock rims once I need new tires. Anybody go for a 17” rim to get more aggressive A/T options?
2020 RTL-E Obsidian Blue Pearl
Consolidated.
On stock 18 inch rims: Any 255/60/18, some 265/60/18. Lift kit actually reduces clearance to some degree as it changes where the tire sits in relation to the wheel well.
Might add this: 17-inch G1 or aftermarket wheels (pay attention to offset: 40-55mm best, minimum 35mm) will work with 245/65R17, 255/65R17 and some 245/70R17 tires -- more choices, more sidewall cushion. But bigger tires may mean you can't use snow cables if you want or need that option.
1 - 7 of 7 Posts
