We've experimented with some of our other Hondas, using mini-split heatpump installation materials as the coolant lines (not on our RL's) caused a splash&splatter effect due to the moisture drip.
There is a tight-form-fitting insulation material, essentially leaving no air gap between the material and coolant line, thus, no condensation forms as the encased aluminum lines no longer sweat. On heatpumps, this material is used to insulate dual copper lines running on outside building walls and the lines can not be allowed to drip any condensate.
With lines remaining dry, there is no issue with corrosion, same as there is no issue of corrosion on heatpump coolant lines. This has no observed effect on cooling efficiency.
