The front turn signals: You have to remove the plastic under cover from the bottom of the vehicle. Its quite a few clips and bolts but simple enough that doesn't need to be shown.
The rear tail lights: Just two screws/bolts, simple.
The interior lights: The on/off map lights and roof lights require you to pry gently at where they hinge. Its the side opposite of where you would push.
The doors: If you have them are from the top
The license plate lights: grab the edge with your finger nails and pull back towards you.
