About to buy a 2022 Ridgeline and worried about water intrusion
16141 Views 94 Replies 31 Participants Last post by  whiskerbiscuit
I have done a ton of research on pickups and had decided that the Ridgeline was the best vehicle to meet my family's needs. I found a local dealer who will sell me a Ridgeline at MSRP (they have several coming in over the next 2 months, but I have to put a deposit down), and I was all set to move forward. However, as I was looking at Ridgeline Owners Club to research tonneau covers, I discovered several posts on water intrusion.
Based on what I have read, I do believe that water intrusion is a potential issue, but I'm having trouble determining how many vehicles this impacts. Is this something that truly impacts a lot of Ridgelines, or is there a vocal minority with problems (which I totally get, as I would be incredibly mad if I bought a new vehicle and had issues with it)?
I would most likely put a tonneau cover on the truck, and it would be garaged at home. It would, however, be in an uncovered lot at work and I plan to drive it in rain, just like I would our other vehicles. Does using a tonneau cover help at all, and is this really an issue impacting a significant percentage of Ridgeline owners?
Thanks in advance for any guidance/wisdom you all might have.
41 - 60 of 95 Posts
What do you guys suggest? I was looking at f150 but it’s more than I need for a truck. And the other small trucks are too small inside. Hmm
Purchase a used Ridgeline that has already proven itself to be leak free, (which will be very easy!)?
Bill
Yeah. It’s so weird to have to go to a car wash and pull sill plates on both sides to feel the foam. I see people use moisture meters.
Colorado and Canyon are not smaller than RL
How’s the interior spaciousness? Of a gmc Colorado? I just don’t trust their reliability
So I've missed a lot and I have a lot to say, lol. Sorry for the long post.
well it’s cold in CT right now. I test drove it and went through the car wash and pulled the sill plate off on each side and felt under carpet. To me the drivers side felt very damp. More so that passengers. But because of the cold. It could of just been the feeling of that foam. I
Showed the sales guy. He isn’t convinced there’s water because he didn’t see rust!!? So I said. Please have them run a hose and pull up carpet to make sure there’s no water. I just really want to see it myself as he just wants to sell a car and there’s about 12/12k miles left on the factory 36k. If it does leak. I am not sure I want to bother them tryin to fix it a million times. It sucks because I love the vehicle. 2021 RTL E.
It can be difficult to tell at first because it is very cold and clammy feeling under the carpet. But the ones that I have found leaking, it was very apparent. My hand came out obviously wet.
I test drove mine and took it to the old school wand style car wash. I removed the sill plates and also some of the plastic trim at the back of the cab under the rear seat. It all just snaps off…no tools needed and very easy. Then I spent 10-15 minutes spraying water onto the rear window and in the bed, making sure to push it to drain through the front of the bed rather than to the rear. I would stop periodically and go inside and thoroughly check for water. You can get your hands all the way to the back of the metal cab wall with those trim pieces removed. This is where the water streams in if it’s leaking. I wedged my fingers in every nook and cranny and never felt a drop of water. So I put it back together and bought it. I have checked it three times over the last 10 months immediately after long soaking rains and thankfully found no water. But you are going to have to be willing to put the work in to check any RL you consider buying. Do not count on the dealer to do it because they will make a half-hearted effort at best. I showed one dealer (not a Honda dealer) that his 21 RTL with 6k miles was leaking through the back window and he basically said Honda warranty will take care of it.
Bill
In all seriousness, I am not sure if you are being serious or sarcastic here. How exactly would one go about purchasing a used RL that has been proven to be leak free?
I don't know anything about moisture meters but pulling the sill plates and sticking your arm under the carpet up to the elbow on each side takes all of 60 seconds.
According to the numbers, they are, at least on the inside. The big number is width. The RL shows to offer roughly 5" more hip and shoulder room than the GM mid size trucks. I honestly don't know how Honda did it but there is noticeably more interior room in the RL than any other mid-sized truck.
Reactions: 1
Also daveroski79, to those saying maybe you should consider another brand...not the worst advice but the problem with that is that the RL is a very unique vehicle. The market is expanding but there is still nothing out there that directly compares to the RL in terms of comfort, space, and overall practicality. It's a shame to have to consider a vehicle that doesn't meet your needs as well over an issue like this. If you have determined that the RL is what you want and need, my recommendation is that you stick with it. Completely educate yourself on what to look for and how to look for it. Commit to not buying until you find one that you are completely satisfied with. Be willing to walk away if a dealer doesn't want to cooperate with your concerns. Understand that this may take some time and a few failures before you find that one. That's what I did and after 10 months of ownership, I would say it was worth it. If mine is totaled, stolen, spontaneously combusts, or is hit by a direct meteor strike today, I'll start the search process over again tomorrow.
Common sense, where when looking at a used Ridgeline, which would have obviously encountered rain, or a car wash, sometime in it's existence where just pulling the sills and checking for any evidence of water infiltration. If none, then obviously it has been leak free?
Bill
@Starquesbd22 Wow. Thanks for your reply. This is very good deal and I still have 12 months of warranty if it did leak. But. I hate to have a headache. I wish it was warm out to test this better.
What year was yours again?
This would be a 2021 RTLE w 26k miles factory tonneau cover , running boards (only so my 4 year old can get in is why I want them) , mud flaps, all season mats For only $36500
Bill
So you're suggesting that he do his due diligence in checking for leaks in any RL that he considers? I believe that is what has already been suggested and is being discussed. I took your comment to suggest that there was some way to very easily identify the RL that has not leaked and unfortunately, it's not as simple as that. The potential buyer is going to have to prove it for themselves. You cannot trust the dealer. You cannot trust the private seller. You don't know when the truck last saw rain or a carwash or how it was parked during those times. You don't know if it's been wet and dried. And there are no other signs other than the presence of water which can be difficult to actually detect. I'm sorry for being so long-winded but I guess my point is that it is not an easy process at all. But it is IMO, worth the effort.
Long story short, I have found leaks of varying degrees and unknown origin on 3 different RLs (a used 20 and 21 and a brand new 22). I haven't looked at pricing since I bought mine and I know it varies by region but I paid a good bit more for my used 22 RTL (even though it only had 800 miles on it). Off the top of my head, I'd say that is a fair price on your 21 RTLE.
If I were you and this is the one you want, I would make every effort to check it thoroughly. Best bet is to park the truck facing just enough downhill that the water will run forward and then soak the rear window, area where bottom of rear window meets front of bed, and front of bed floor for a solid 10-15 minutes. If there's a leak, enough water should enter under the carpet to be felt through the sill plate openings. But removing those 2-3 plastic trim panels under the rear seat at the back of the cab is even better. Look and feel everywhere you can. If you can't get access to a hose, a wand carwash will work but you need to spray a lot of water into the bed and keep it draining to the front. It's not about trying to force water in anywhere, it's about keeping it all flowing forward. If it's dry after all that, I'd buy it. On the off chance that you do encounter an issue over the next 12 months, even though that's a pain that no one wants to go through, Honda will make it right.
I agree totally. I’m going to take it for a second test drive. Go into the bay where I can spray water. Do I need any tools to take the panels off the rear wall? I know the sills are easy to take off and feel with my hand. Do you have any pictures of what to take off?
Thanks again you all are great here.
Dave
Haha what I should do is bring a 5 gallon bucket. Fill it up and splash it hard into window and bed. That should show If there’s a leak
#1, the reality is that the chances of any Ridgeline having water intrusion starts out as being very rare, practically nill to none!
Now, if a person just wants to do a quick confirmation on a used Ridgeline that has been out in the real world for any period of time, remove a sill, look for any evidence of water, feel for any evidence of water, replace the sill and do the other side, 3-5 minutes total tops.
Pardon my saying so, I believe that you are really proving the point of how to make a mountain out of a mole hill, Starquesbd22?
Bill
Take a paint stick and shove a puppy pee pad under the carpet. That will quickly tell you if there's any moisture under there, regardless of temperature.
Dave
How far away is the dealer from your home? Ask them for an extended test drive and take it home to check it out if they will let you. A vehicle is probably the second largest purchase that most of us will ever make and often we make a decision based on a 15 minute test drive, lol. I've done it so I can say it!
You do not need tools for the panels. It looks like one big panel that runs the length of the cab but it's actually 2 or 3 separate pieces best I remember. They are snapped in. Just grab an edge and give a quick, firm pull. I never broke any clips when removing them. They are a little tricky to navigate around the seat belts but you will understand when you see it. Taking these off allows you access to the rear cab wall and the rear edge of the carpet so you can stick your hand down from that direction.
Vehicle Automotive lighting Automotive design Car Motor vehicle
You certainly could. I'd repeat it several times and pour it slowly so it has time to find the little holes. But filling a bucket from a carwash wand is a task in itself, lol.
Bill
You are flat wrong. How can you say that "the chances of any Ridgeline having water intrusion starts out as being very rare, practically nill to none!" when the poll of over 300 owners on this very forum is currently showing right around 23% as having water intrusion issues???
I understand your point about checking for water intrusion but you seem to indicate that it is a simple, quick, and fool-proof process when it is absolutely not. If you want to be truly confident in a $30-45k purchase, you have to put more into it than that. Buying a RL after a 3-5 minute inspection for this issue would be foolish.
I am absolutely not making a mountain out of a mole hill. I am trying to educate potential buyers (who have asked, I might add) about the mountain that very few are aware of and a handful want to deny exists.
My friend lives close to dealership. I will give it a good water test and take a video if there’s water.
Thanks again. I’ll report back later!
Please do. I hope you are able to report back that it was all dry and it's in your driveway. I've owned a LOT of trucks over the past 10 years. Full-sized Fords, Chevy, and Dodge, Rangers (old one and new one), and even a Maverick for a short time. Out of all of them, the RL is by far the most comfortable, roomy (for its size), and practical for everyday use.
Awesome. Good to hear. I was debating the f150 but feel this is more practical. Plus I like naturally aspirated Honda v6 are bulletproof.
No issues w transmission?
Another #1 point, People are mostly drawn to Forums such as this to mostly complain, so 23% of people that already are likely to complain is not reality in my book.
#2, I make a point to seek out other Ridgeline owners when I have an opportunity, and of all of those owners over the past nearly 4 years, not a single one, I will say that again, not a single one, has had anything to say about water intrusion. Those are real numbers to me.
I'll stick to my opinion of making a mountain out of a mole hill!
Bill
Bill. While you maybe correct , knowing this is an issue. Wouldn’t you rather be safe? Would you check this if you purchased a used Ridgeline? If so, the only reason you know about this is because of forums. Speak up and share issues. That’s the point of these.
41 - 60 of 95 Posts
