Dose it work? How?
It's thicker.Dose it work? How?
For decades, windshields have been made by laminating two layers of glass together using a resin. The resin is ductile which helps hold the windshield together if it shatters. "Acoustic" windshields simply use a different formulation of resin in the middle. I immediately noticed that rain drops hitting the windshield sound different inside the cabin - they sound "lighter" and higher-pitched.Dose it work? How?
Actually, the "acoustic" windshield is 0.2mm thinner than the "standard" windshield.It's thicker.
Acoustic Windshield
Special acoustic laminated glass is used for the first time on the Ridgeline RTL and above trims to help reduce noise entering the cabin. Tuned specifically to attenuate wind-noise frequencies, the windshield glass uses an outer layer of 2.0 mm safety glass, a 0.7 mm thick middle layer of acoustic polyvinyl butyral (PVB) and a 1.8 mm inner glass layer for a total thickness of 4.5 mm. This helps the Ridgeline place at the top of its class in wind-noise performance. The windshield also incorporates UV light-absorbing technology. The RT, RTS and Sport trims utilize 4.7 mm thick laminated glass with 2.0 mm outer and inner layers and a 0.7 mm regular PVB middle layer. - 2017 Honda Ridgeline Press Kit
Thanks for the info, that's interesting. I remember reading about the new MDX when it first came out and whatever automotive "journalist" simply said that the new windshield is thicker. I should know not to trust a source like that!Acoustic Windshield
Special acoustic laminated glass is used for the first time on the Ridgeline RTL and above trims to help reduce noise entering the cabin. Tuned specifically to attenuate wind-noise frequencies, the windshield glass uses an outer layer of 2.0 mm safety glass, a 0.7 mm thick middle layer of acoustic polyvinyl butyral (PVB) and a 1.8 mm inner glass layer for a total thickness of 4.5 mm. This helps the Ridgeline place at the top of its class in wind-noise performance. The windshield also incorporates UV light-absorbing technology. The RT, RTS and Sport trims utilize 4.7 mm thick laminated glass with 2.0 mm outer and inner layers and a 0.7 mm regular PVB middle layer. - 2017 Honda Ridgeline Press Kit.
I used to be a big Buick (and GM in general) fan. The first time I ever heard the term "acoustic windshield" was in the early-2000s when Buick advertised "QuietTuning", which was a collection of methods and materials used to make the cabin quieter. An acoustic windshield was part of that collection. Since then, acoustic windshields have become very common. One was standard on every 2008 Ford Focus. The Civic now has one. These days, you'll find acoustic windshields all over the place even though they're not often advertised. They've been around for over a decade now. They are somewhat effective at reducing "midrange" frequencies between 1,500-5,000 Hz by 2-3 dB. Its takes a reduction of 10 dB to make something sound "half as loud. So, the reduction isn't dramatic, but if you reduce a little bit here and a little bit there, it adds up to a noticeably quieter interior.Thanks for the info, that's interesting. I remember reading about the new MDX when it first came out and whatever automotive "journalist" simply said that the new windshield is thicker. I should know not to trust a source like that!
Black EditionWhen folks use the term "BE" when referring to Ridgeline, what does that mean?
BE=Black Edition. The second generation's highest end model.When folks use the term "BE" when referring to Ridgeline, what does that mean?
I guess we're stuck with having to get OEM part (windshield) and have it dealer installed ?:smile:Is this special windshield on an old RTS and if replaced what does one look for as far as specs and does it include the heated element for the wipers.
My wife had to get her windshield replaced on her '16 Pilot and they had to use OEM because of the various customized features. I would expect that the same will happen if we need a replacement although it would be something that I would watch for with my insurance company.I guess we're stuck with having to get OEM part (windshield) and have it dealer installed ?
Black Edition. It is the top of the Ridgeline line.When folks use the term "BE" when referring to Ridgeline, what does that mean?
Here in the Southwest, we get really strong winds and although My truck spend most of it's first 10 years in the Garage, the window is severely pitted and I'm considering the same options.So my Dealer has some one that does so called Honda spec glass, is it a waist or is it special, After several years of off and on road, gravel roads and logging roads I have pin head pits that effect driving into the sun and my wipers for cleaning, have full glass coverage. Thing is Ive done this before with my old truck that was traded in and ten years old, my Insurance Company questions it cause its not cracked, but driving with a ten year old pitted out windshield is just as bad or worse in my world. So do I put a rock thru it and call it all good or fight it again. They did replace the one but like everything else im guilty till prove i prove my innocents.
