1 - 7 of 7 Posts
Hello
my 06 Ridgeline has around 325k miles and the engine check light comes on and off from time to time due to exhaust valves needing to be adjusted.
It starts and idles slights rough when cold but drives fine and mpg is about the same as when it was new.
so the question is... how long can I drive like this without valve adjustment before the engine stops starting or running?
It has new water pump/timing belt/spark plugs. New snow tires for snow trips.
but the car looks like it has 325k mi on it with dents primer sprayed here and there. It’s probably worth 1k if I were to sell it. I had to get the timing belt done as I didn’t want to get stuck while in the mountains.
this is my snow trip only car and I want to limit my spending on it due to low value
Experience from here and Piloteers.org tell me that the valves get "tight" and tight valves are not noisy.
Amazing that you've made it this far without doing them, but if you only value it at 1k, I wouldn't waste the money, OTOH, it would be an "invaluable" test case to "learn" to DIY them. Front 3 should be easier, than rear 3, posts here and YouTube Videos on "How To"...
YMMV
I'm just a couple thousand miles ahead of you and my CEL is also coming on sporadically. I'm planning to take it in for timing belt etc and I'm going to ask what codes etc are happening. Not the expert, but my hunch is we both have emissions issues. I'll update with what I learn.
2019 Sport Lunar Silver
To adjust valves or not.
The thing is, if a valve gets tight enough it will damage the head & you'll know it, but you won't hear it. They HAVE to be inspected. All the guessing & internet searching can't tell you if it's needed.
Saying that, I have done several V-6 valve adjustments, & unlike the 4 cyl, I have never found a valve dangerously tight. Same with the T-belts. The V-6s seem to last longer.
I am not familiar with the newer engines as I quit working on them a few years ago.
I'd recommend having the valve adjustment done when due.
Hard to tell with that high mileage. Chances are the exhaust valves are very tight.... and I suspect you run the risk of a burnt valve or three. But whether or not it's worth getting them adjusted is up to you and how long you want to keep the Ridge running.
Update: Just an FYI for those who own high mileage low value rigdelines. my 06 ridgeline has over 350k mi w off and on CEL, could use a valve adjustment(slightly rough idle after cold starts) and when running a scanner P0175 code pops up. Even when the CEL is off, P0175 persists
Recently I was concerned w CA smog test but It PASSED! I just had to get it tested when the CEL decided to be off.
Hoping to drive my 06 for another 10 ski seasons...
1 - 7 of 7 Posts
