So I purchased a set of Clazzio covers for the truck. While doing so, I decided to add heated seats as well. When wiring the heated seats, can I use any unused fuse slot located on the panel in the front of the truck?
I would love to see pictures of this. I've been thinking about doing the same thing. I would use an add-a-fuse and use an existing fuse that is powered only when the truck is on.
I installed aftermarket seat heaters 3yrs ago in my stock cloth seats. I tapped into the rear seat acc socket (which I never use) to feed the drivers seat heater. I then tapped into the front acc socket ckt for the pass side heater. The front ckt is fused at 20a and the rear at 10a. Each heater draws 4a so it leaves a lot left for accessory's. I've never had any problems and use the front sockets a lot with the heater on as my wife and I are together most of the time.
