Frustration to say the least!!!
When I ordered my Axxera AXV820 (also a 5 ch unit)I also ordered the 2011 Ridgeline compatible harness with steering wheel integration.
The AXV820 has a Sub Out single female RCA for the Subwoofer but there is no female RCA to hook into that because the OEM Subwoofer was wired to a plug in the back of the OEM Stereo that is no longer used. Would I be able to transfer the 2 subwoofer wires from the old OEM harness to a spliced RCA female connector???
If not, is a mono channel amp 250w from rockford fosgate sufficient to power the OEM Subwoofer so I don't have to also replace it?
