1 - 4 of 4 Posts
06 RT Ridge. I’m ready to junk the whole truck lol. Changed out the stock radio to Pioneer AVH-P4400BH. From the get go the AM/FM reception has been the shits. I re checked the wires to the amplified antenna and everything is good. I started thinking the antenna booster was crap. Went to auto store picked up a aftermarket fender antenna, plugged it in and grounded it with a wire to battery. Held antenna up in the air as high as I could and still no AM at all and spotty at best FM. I’m now thinking I got a shitty Pioneer HU receiver. I’m at the end of my rope. Thinking of getting a new Sony HU.
I remember my '06 with stock radio had pretty awful FM reception, but not nearly as bad as you are describing it. I would guess the antenna connection on your Pioneer has a bad connection or the truck antenna had a short somewhere. You could test it with an ohm meter to find out for sure.
2104 Honda Ridgeline SE
Have you connected the blue antenna wire to the red 12v switched wire? This is a common problem with new HU install. I went and changed my antenna because the stock antenna isn't great unless matched with the stock radio. Do a search of this forum for antenna or radio reception or look here...
1 - 4 of 4 Posts
