I don't remember the actual temperature, but I think it should be in the high 60's to low 70's.Crispy said:Unless I have the recirc on, the air coming out of the A/C is really not that cold. Yes, I have it set all the way to the left.
Is there a temperature the air should be coming out of the vents?
Try this next time you are approaching your RL. Press the unlock button and immediately release it. Press it again but this time hold it and the windows will come down. Keep your finger on it until the desired amount of window is opened then release the button. Now you only have to push once and hold instead of pushing three times.5S Dude said:Crispy, I've got the black Ridge and it's always a hundred degrees inside when left out in the sun! I typically press the unlock button three times while walking up to it and all four windows roll down before I jump in. It helps a little. I had limo tint placed on the two rear windows and rear slider and 15% put on the two front one's and this helped as well. Can't wait for winter!!! It may be the type of freon they use on all air conditioners now days.![]()
I hate to disagree but I have found myself redirecting the vents around the steering wheel to keep my hands from getting too cold. At least in mine, the AC works greatWhaleya said:The AC isn't that powerful in the RL.
As for measuring it, remember the cooling capacity is a function of both the temp of the cooled air and the volume of air.
Believe it or not, the AC on my S2000 is VERY cold.doubledutyemt said:R134a just doesn't put out that good COLD air that most of us remember from R12. just remember to tell your grandkids about the good old days when AC was really cold!
The S2000 has as ultra quiet awsome A/C system!shingles said:Believe it or not, the AC on my S2000 is VERY cold.
I know ealier R134a equiped cars weren't very cold... but the newer ones are pretty cold.
That's going to leave a mark...STEVE FROST said:It does take a while to cool down when the car is heat soaked, but after its cooled down, takes about ten minutes. I would not need a gun rack if I was a hunter,I could just crank the auto temp to 60 and hang the rifles on my nipples.
