Hi,
Howdy!
The HVAC looses pressure but very very slow, it passed the garage test, they told me that cannot find any leak. Apparently may be a compressor leak through the seals but very slow not detecting by the sensors and not through the die test. However, I am fine with that for now, I have to recharge it every two months (during summer).
What I did wrong: The Air cond worked almost fine, cold air but not so cold, I had low pressure (checking on the dial meter). So I put one more can of refrigerant and it was too much, I lose the pressure a bit but I noticed that before to lower the pressure, the clutch wanted to engage for a seconds and then disconnects. Apparently it has some protection when the pressure is too high.
What happened: After lowering the pressure, the clutch engaged and worked fine, cold air. After driving about 20-30 km, I noticed it blows warm air. Checked the pressure and it was again way too high! Lowered to the proper levels but the clutch does not engage anymore. Where to start troubleshooting?
I have done the HVAC self troubleshooting as per the technical manual and the display ends to be OFF and that means there are no problems detected. Also checking all the sensor temperature seems to be OK, no errors (by pressing Auto and Recirculating at start).
I have also checked all the fuses as per the manual (two 7,5A under the hood and under dash, the 30A for the clutch) and the HVAC compressor relay located in the fuse box. I am not sure what to do next.
Howdy!
